Confession time...
[Closed] Confession time...
[#1121868]
I think I've borked my front brake! I was changing the pads on my Tektro Auriga Comps and I the lever kinda, sorta got pulled, (only just discovered this is a bad idea but it kinda makes sense in retrospect.) As you can probably guess the pistons are now too close together, I can get the pads in but they're tight against each other. I've tried easing the pistons back with a flat chisel but they only go so far.
Obviously I'm a tw*t and need help, if anyone's willing to oblige I'd be very grateful.
Posted : 11/12/2009 7:44 pm
Big flat object should should do it, hope do a big flat spanner thing for it. do it with the pads out. but dont damage the pistons.
Posted : 11/12/2009 7:46 pm
If you can get a flat-bladed screwdriver in the gap then GENTLY twist the screwdriver so that the pistons ease apart. Once you've done that get an 8/10mm ring spanner & using the ring end push the pistons back into the main body of the brakes. It will happen, just take your time and do it slowly.
As a tip, when you're next at your LBS buying something ask them if they have any of those little plastic spacers disc brakes come with to hold the pistons apart. I use them when shifting the bike in the car with the wheels off.
Posted : 11/12/2009 7:52 pm
Worth wrapping the screwdriver in insulating tape,to cushion it against the pistons.
Ian
Posted : 11/12/2009 8:00 pm
Had to improvise with the tools a bit but I've got it done. It's rubbing very slightly but a bit of tweaking should sort that.
Cheers guys. 🙂
Posted : 11/12/2009 8:08 pm
