Looking to take the hassle out of tubeless tyres and also inflating car tyres. Would this have the tank capacity to do tubeless easily......
[url] http://www.screwfix.com/p/stanley-b6cc304scr004-24ltr-air-compressor-240v/85834 ][/url]
That link isn't working for me but if it's a 24ltr tank like it says in the URL then it would be more than capable of inflating tubeless tyres & doing the occasional car tyre too.
I think it's because my work webservers are in Germany.
Same here - servers in France so doesn't work! Website too clever for it's own good!
Yes - a 24 litre tank is good for tubeless, but it's as much about high flow rate that's sustainable. A tricky tyre could take a full tank while you wiggle the tyre.
24l can top up 4 van tyres but one was nearly flat and took over a tank. For a couple of PSI that's more than enough.
[url= http://www.screwfix.com/p/stanley-8216035scr011-24ltr-compressor-with-5-piece-accessory-kit-240v/48089 ]£50 cheaper[/url]
Machine mart usually have some good deals on compressors.
Be careful with compressors. I use one and a couple of weeks ago managed to over inflate (in a rush and wasnt watching what I was doing that closely) the tyre....BOOOM. Ripped the tyre off the 6 week old wheel, managed to right off the rim completely. Was an expensive mistake to make. So ensure you get a tyre pressure adapters with gauge.
definitely makes life easier when used correctly 🙂
tonyplym - yes clocked that one, even better when you consider the accessories too!
