Compression tights ...
[Closed] Compression tights under padded shorts?
[#2669139]
Hi, doing a couple of long distance endura events including the uk24 in a few weeks and wondered what people's experince was of compression tights or shorts underneath padded shorts?
Does this cause any extra friction, is it a comfortable setup? I've got some dhb tights but they have become loose over time and I just use them for running now, was looking at some of the max gear stuff which seems very good value for the tights, any experiences?
I guess the answer would be to buy the compression tights with in built pad but they are uber expensive?
cheers
Matt
Posted : 17/04/2011 9:10 am
Probably get a lot chaffing trying them that way. I sometimes wear them over lycra. You're right though - the ones (Skins) with built in pad are pricey, but no more so than Assos etc.
Posted : 17/04/2011 9:38 am
Would it not be really difficult to pull them over lyrca, particularly something with a thicker pad? Probably a good market for someone to do a sensibly priced compression tight with pad like dhb or max gear?
Posted : 17/04/2011 9:43 am
Yep, when I've done it it's been over thinnish shorts with a thin pad.
Posted : 17/04/2011 9:58 am
Probably not ideal for the 24hr race then when more padding the better!
Posted : 17/04/2011 10:07 am
I've tried them to stop cramp, didn't work plus lack of grip on skin made my padded shorts slip down.
Posted : 17/04/2011 10:21 am
Wear mine under shorts and don't get any rubbing issues. They are 2XU versions.
Posted : 17/04/2011 10:22 am
Gaylords! 😆
Posted : 17/04/2011 10:30 am
There's nothing gay about SCIENCE, science fact 🙂
Posted : 17/04/2011 5:25 pm
