Compression less br...
[Closed] Compression less brake cable housing - really draggy?
[#9962440]
Just bought some gusset compression less cable and you can barely pull the supplied inner through it!  Is this normal?  Should I be sending it back?
Also it's really. Stiff and holds its shape, again is this normal?
Cheers, Keith
Posted : 28/04/2018 11:20 am
Haven't used the Gusset stuff, but no, the stiff movement of the inner  doesn't sound remotely normal - neither the Jagwire or Yokozuna compressionless housing I have does this. The stiffness of the housing may be a thing, as I've not used the Gusset stuff I can't say for sure, the Yokozuna stuff is very stiff. Regardless of that, the inner cable should be sliding freely. Are you sure there's not a broken strand on the inner which is catching or similar?
Posted : 28/04/2018 11:42 am
Is this on a road bike - with drops?
Remember that tight bends should be avoided and so cause a problem on road bikes as there's a bend under the tape. Jagwire provide a flexible "noodle" for this section.
Posted : 28/04/2018 4:05 pm
I've not even fitted them yet, just got them out of the pack and tried to pull the inner through.  Which I had done 2 days before with a standard cable no problem.   Think I may be sending it back.
Posted : 28/04/2018 4:29 pm
