Having been thoroughly put off buying another USE suspension seatpost can anyone recommend a nice rigid one.
Will a carbon or ti one feel any different to a cheap aluminium one?
I've ridden behind someone with a Ti seatpost and it was visibly flexing, so it can be a lot less harsh than an aluminium one.
I've bin trying out a Cane Creek Thudbuster, and I have to say it's not that bad at all. A lot better than I expected tbh.
Heavy though, and needs regular maintenance I'd imagine.
Carbon was the most 'comfy' rigid 'post I've tried, but I'd like to try out a Ti one see if they work as claimed.
Looked at thudbuster, jeez they are ugly.
I've got a Thudbuster, really quite good, takes the edge of off - but as above heavy.
I don't mind the industrial look but the Lizard Skins neoprene cover makes it look a little better and is pretty much essential in sandy/grit/mud Peak conditions.
Got if from Bike24 in Germany, lots cheaper than anywhere else at the time.
er....You guys[i] are[/i] using saddles as well right? I find they make any seatpost a little more comfy...
er....You guys are using saddles as well right? I find they make any seatpost a little more comfy...
+50
i use i-beam saddle and post combo, much comfier than most othe seatpost and saddles
I'm using an SDG Bel Air saddle on a Thomson post and find it comfy, get no back ache even after 3-4 hours in the saddle.
whilst on a demo at Charlie the Bike Monger (awaiting a Spearfish ride - sadly too small) I had a go on a Niner SIR - just to see how it compared to my Swift - the SIR had a Ti post (Van Nicholas) I was very bendy but also noticeably comfy.. If Charlie has sold them I would have bought one on the spot!but alas he did not.
also thudbuster do a compact version though less travel.
