I'm wearing out the stock grips that came on my 2010 Pitch Pro, and will have to replace soon. Any recommendations for comfortable lock-on grips that'll absorb a bit of trail buzz?
Cheers - Robin
I find ODI Yeti's hard to beat, v comfy and knock out a lot of buzz...
ODI Troy Lee
I have used ODI's before and they were good but I am now using BBB cheap and chearful grips and work ust as well.
ODI yeti...best grips i've ever used. Ritchey foam ones are good if you've got massive hands cos they have quite a girth!!!
Ritchey WCS foam.
Oury are nice, though quite thick if you've got smaller hands.
Happy with the ones I've had from superstar
I use ODI X-Trianers.
They're as good as grips can be, imo.
ODI Yeti's for me.
Lizard Skin Charger, squishy and gripy.
I use Lizard Skin Northshore as they're nice and fat for my big hands.
Before that i used Sunline grips which were pretty comfy but wore a bit quicker. However, as Sunline are leaving the mtb market, CRC are knocking them out half price at £7 and at that price they are well worth a punt?
esi chunky
What Ton said!
You want some nice fat ones. Sunline ones on offer at CRC at the moment. The do the trick nicely
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=30937 ]here[/url] and [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=30939 ]here[/url]
They're very comfy. I've stocked up 😀
What Ton said again, but the ESI racers edge.
By a long way the comfiest grips I've used, better than foam and rubber, loads of shock absorption.
OURY not the lock on version are the best I have found so far.
Nice recommendations - I appreciate it. Gonna check all these out and maybe try a couple of different ones.
