Comedy customer ser...
[Closed] Comedy customer service exchange with Evans (Arkose content)
Clearly a fob off. Why on earth would Andy keep pointing OP to those crappy seatposts
Posted : 22/10/2014 5:36 pm
P.s. The confusion (and hence, me posting this thread) arose as follows. I didn't include this in my OP as it would have been a very, very long post...
Here is the first email I sent to Evans yesterday:
Hi,
A couple of months ago I ordered a Pinnacle Arkose frame from you (see order below), which I've just got round to starting to build up. Much to my dismay, the seattube appears to be badly reamed - I've tried two 27.2mm Thomsons and a USE Sumo post, and all of them have a considerable gap between the post and the frame tube - more than a coke can shim can take up.
I'd really like to keep the frame, as I've ordered various parts to fit it, installed the headset and bottom bracket, and even cut the steerer on a set of carbon forks to fit. However, I can't see a way around this seat post problem. Please can you offer a solution?
Thanks a lot,
Adam
I got this response from Sam:
Hi Adam,
Thank you for your email
I am sorry to say if there is a defect within the seat-tube of the frame this is a problem that is almost impossible to fix.
There are various mays that this could be bodged to work but with a new frame nobody wants to have to bodge it to make things work.
As such I feel on this occasion the only option would be for us to get the frame back with a view to replacing this under warranty.
Can you confirm if you have a store nearby you could drop the frame into or if you would need that collected please?
If you have any other questions please do not hesitate to contact us.
Kind Regards
Sam Bristow
Happy days! Aren't Evans brilliant? I emailed Sam my address, and got the following response from Jack:
Hi Adam
I have spoken with our warranty department and before we can look into exchanging the frame for you we will need some clearly detailed photos of the issues you are having with the frame. This will help us to get the ball rolling with the warranty procedures.
Could you also include a phot of the entire frame as well as the serial number on the bb shell.
Also could you please confirm whether you have been using a seat post clamp as there will be play until the seat post clamp is tightened.
Once we have received these photos we will let you know of the next stages regarding the warranty.
Kind Regards
Jack
Okay, that makes sense. So I sent some photos and a video. Then, to square the circle with this thread, this morning I got the email from Andy:
Hi
I’ve looked at your video, and you are right the 27.2mm seat post is too small, have you thought about trying a 27.4 or a 28mm.
Here is a link to a seat post with these measurements. http://www.evanscycles.com/products/vavert/single-bolt-400mm-seatpost-ec039090
Kind Regards
Andy
Evans Cycles
I think the lesson here is that Evans need to assign specific people to specific cases.
Posted : 22/10/2014 5:42 pm
Ahaaaa - not such a CS fail after all then
Posted : 22/10/2014 5:45 pm
Moral: Don't cut the steerer till EVERYTHING else is sorted!
Posted : 22/10/2014 5:48 pm
Clearly a fob off.
Once a warranty is mentioned and photos and frame numbers are requested and sent, as they have been here, it'll be followed with either a 'yes' or 'no, this is why'. Unless I'm mistaken (OP?) it hadn't got to that stage. You could take it as a fob-off or see it as misplaced advice, but since no-one from warranty had replied either way yet and the decision and process lies with warranty it wasn't an answer either way.
.. posted while others were posting .. yes, specific people to one case/enquiry would be good, agreed, it could slow things up but would offer better continuity.
You should also probably buy jameso a pint, he deserves a pint for all the work he has done on here and for the fact that a good percentage of us really want to buy the bikes he is making!
Posted : 22/10/2014 5:49 pm
Seems the OP should really have put all the info in his first post.
Does make things look much worse than they were.
Posted : 22/10/2014 5:50 pm
Posted : 22/10/2014 6:13 pm
seems to me the last email was a guy trying to help you achieve your stated aim:
Posted : 22/10/2014 6:53 pm
I nearly posted that the advice to try a different size seat post might have been thinking of an option as to how you could keep that particular frame
Any way all's well that ends well
Posted : 22/10/2014 7:12 pm
I think it was a bit unfair of the OP not to disclose all the emails at the beginning, particularly given the thread title. Looks like a case of misunderstanding really.
Posted : 22/10/2014 7:32 pm
I feel used
So Jack and Sam @ Evans are cool.
Andy isn't so much.
James @ Pinnacle is cool.
OP hid the truth from us temporarily so we'd all jump on the "we all hate Evans bandwagon". OP is definitely not cool but has a new frame on its way.
As per winston, I feel used and dirty. I'm going to cry in the shower with my clothes on.
Posted : 22/10/2014 7:42 pm
 Earl
I support OP on this one. He did what Evans CS requested. Evans should have assessed the frame properly. If concluding that it was a warranty replacement they should have contacted Pinnacle to see if they could get a replacement frame.
If no stock was avail, then suggesting a 27.4 seatpost should have been last resort suggestion if the OP insisted he still wanted it.
Posted : 22/10/2014 7:49 pm
"I'd really like to keep the frame" sort of explains why Evans were suggesting solutions other than a replacement.
Posted : 22/10/2014 8:28 pm
 sv
Why did I sell my Arkose, sigh...
Posted : 22/10/2014 9:03 pm
I'm going to disagree here. I didn't have multiple conversations going on with Jack, Sam and Andy - it was one email chain. And I interpreted the situation as Evans changing their stance from:
1. (yesterday) the frame is faulty, an exchange will be no problem; to
2. (today) the frame is fine, you don't understand how seatpost sizing works and you should try buying a load of different size posts to find one that might fit instead.
Which I thought was pretty comically bad customer service, hence the thread. There was no intention on my part to portray the situation as being worse than it actually is.
Anyway, all is clear with Evans now. Fingers crossed I'll get a frame that is fit for purpose sooner rather than later.
Posted : 22/10/2014 9:30 pm
& after all that I'd still never use Evans.
Posted : 22/10/2014 9:32 pm
Im going to take my previous statement back after the OP did not tell all.
All Adam tried to do was help, as you wanted to keep the frame. He did what he thought was right and offered you an outcome/solution. thus keeping your frame.
Who cuts the steerer before even riding the bike.....
You already had the warranty going though.
I think next time you should be so quick to pick up the pitch fork.
Posted : 22/10/2014 9:43 pm
Booo! OP, Booo!
...and no I'm not saying Boo-urns!
Posted : 22/10/2014 9:44 pm
No, I didn't. Once I'd sent the photos and video confirming the problem the only responses I got were the ones from Andy suggesting I buy random size seat posts to find one that fits.
And this is still part of the exchange is still quite funny in my opinion:
Hi
Kind Regards
Andy
Evans Cycles
Andy,
Thanks for your response. However, I have several problems with it:
1. I don't want a "Vavert" seatpost, and with the exception of Thomson I'm not sure any other brands make seatposts in 27.4mm or 28.0mm sizes (and you don't even stock Thomson in those sizes);
2. How can I be sure a 27.4mm or 28.0mm seatpost will fit? What if it's 27.3mm, or 27.5mm? I'm not willing to buy three or four different posts to find one that *might* fit.
3, MOST IMPORTANTLY, as I stated in my original email, the seattube is clearly badly reamed. This frame isn't supposed to take a 27.4mm or 28.0mm seatpost, it's supposed to take a 27.2mm one. And that doesn't fit. The frame is therefore clearly defective.
I trust you will reply with a more reasonable solution promptly.
Kind regards,
Adam
Hi
As previously mentioned, I suggest you look at a larger diameter seat post available from the Vavert range.
Kind Regards
Andy
Evans Cycles
However, if this is genuinely a sensible customer service response, and I'm just being unreasonable, then I apologise to everyone and you have carte blanche to get the pitchforks out.
Posted : 22/10/2014 9:47 pm
Well given that you'd asked for a solution as you'd rather keep the frame then that's not a completely ridiculous reply. I think you have unfairly maligned Evans.
Posted : 22/10/2014 9:53 pm
But that suggestion came after they'd initially acknowledged there was a fault with the frame and would replace it.
I'm not a bike expert - I don't, for example, work for a national chain of bike shops - but if such an expert tells me a frame I've bought is faulty and they will replace it with one that isn't, then when I try and arrange that another expert suggests that instead I should spend my own money attempting to solve the problem with a solution that might not work, well... that's not an appealing proposition in my book.
Posted : 22/10/2014 9:58 pm
Out of interest OP - did Evans suggest you to disclose the other emails to us?
Posted : 22/10/2014 10:07 pm
No, I just thought on balance I should tell the whole story. If it turns out that that makes me look like an unreasonable tit, then fair enough and apologies all round 😳
In my first post I did say that the email I quoted from Evans was the latest part of our exchange.
Posted : 22/10/2014 10:09 pm
Sits on fence with pitchfork deciding who to attack
its more than likely the OP as you were deceptive over the e-mail chain and they seem to be offering solutions so you can keep the frame as their initial response - never retracted - was to offer warranty.
If you say I dont want to try seatposts as I want a new frame i expect them ot say
OK no problems
Posted : 22/10/2014 10:12 pm
Fair enough. I think it was the correct thing to do (disclosing the earlier emails).
Posted : 22/10/2014 10:15 pm
OK no problems
Which is basically exactly what they've done in the end 😀 . Really going to disagree that I was "deceptive" though.
Posted : 22/10/2014 10:17 pm
well you withheld the bit where you said you wanted to keep it and the bit where their initial reply was to accept your warranty claim
I am not sure how you can think neither of these were pertinent or withholding it was not misleading
Deceptive is too strong a word though , no offence meant and I retract that bit.
Posted : 22/10/2014 10:38 pm
Just a bit of a misunderstanding on both sides IMHO, and I don't think the OP deliberately attempted to portray it as something it wasn't by not posting all the e-mails, just that he didn't realise how it made it look different.
Though everybody seems to be ignoring the most significant thing in this thread - that it's possible to specify the thickness of a coke can to the nearest thousandth of a mm.
Posted : 22/10/2014 10:49 pm
Americans dont use metric
Posted : 22/10/2014 10:51 pm
me
Posted : 22/10/2014 11:07 pm
Why is Daniel Craig holding you?
Posted : 22/10/2014 11:16 pm
Page 2 / 2
