Coloured Rim Strips
[Closed] Coloured Rim Strips
[#9329627]
I've noticed that some fat and semi-skimmed rims have coloured strips in the cut outs. Does anybody know where to buy coloured tape that would be suitable for a mulefoot rim.
Asking for a friend, no way would I be that sad 😳
Posted : 15/05/2017 8:29 pm
 JoeG
I use white [url= http://surlybikes.com/parts/od_crank1/rim_strip ]Surly Rim Strips[/url] on the Mulefut rims on my Fatty. 64mm width IIRC (the next to largest size).
Posted : 15/05/2017 9:00 pm
You can use pretty much any flexible material, and then just lay the standard strip over it. Or variations on that theme- mine is just really wide electric tape, it's both visible tape and tubeless tape for lightness. Because obviously saving a few grams off the rim strip is essential before you fit a 1600g tyre.
Posted : 15/05/2017 9:07 pm
Mine just came from GafferTape.com
Posted : 15/05/2017 9:08 pm
Used fattystripper.com rim strips as well as the latex sealing stuff. But that was because i couldn't get duck tape to seal without a shed load of sealant.
#amateur
Posted : 15/05/2017 9:34 pm
Cheers all. I'll have a look around and see what craziness is available.
Posted : 15/05/2017 9:42 pm
