Cold setting an old...
[Closed] Cold setting an old frame
[#2311539]
Got an old steel frame that I'd like to use. Problem is it's 116mm spacing and I'd like to use a modern wheelset.
The frame is in great condition so it's not likely to fracture.
The other issue is the lack of a mech hanger, as it has the old semi horizontal dropouts.
Though I could run it singlespeed.
Posted : 24/12/2010 4:15 pm
SS, 120mm track hub?
Posted : 24/12/2010 4:18 pm
I was thinking of cold setting it even if I went singlespeed and using a budget 700c wheelset with singlespeed converter on the freehub.
Posted : 24/12/2010 4:26 pm
It'll go I'd have thought. Stud bar and tighten two nuts from inside the frame to push it out. You'll have to over do it to account for it springing back.
Posted : 24/12/2010 5:58 pm
20mm is asking a lot, it'll be okay for a while but...
Posted : 24/12/2010 6:01 pm
It's only 7mm per side.
Posted : 24/12/2010 6:03 pm
Track hub and ss it its only 4mm you will prob just manually squash it in. I used to run my cx with 130 spacing with a 135 mtb hub, and that was an aluminum frame so steel will be better
Posted : 24/12/2010 6:08 pm
 rob
yup no problem done a few old bikes now
if you have a look on sheldon browns site it shows the proper way to coldset with a bit of wood
me i just stand on one chainstay and pull the other one up a bit then turn the frame over and pull the tother one a bit.
if you want a mech hanger i have probably got one in the shed you can have
Posted : 24/12/2010 8:45 pm
And what?
Posted : 24/12/2010 8:53 pm
and it'll giver way and crack, at least thats my experience
Posted : 24/12/2010 8:58 pm
it will be absolutely fine.
Posted : 24/12/2010 9:27 pm
Done two first one broke apart brazing on the seat stay brake bridge..the second I G clamped this bridge and the chain stay bridge(awkward I know) came out well.
Good luck
Posted : 24/12/2010 9:31 pm
