Coil weight
Coil weight
[#13162008]
How on earth do I work out what weight of coil I need? 205 by 65 trunion mount air shock currently fitted on a 140mm travel bike, tried a calculator and got lots on 60/40 distribution etc.
Posted : 20/02/2024 11:16 am
Start with a calculator and then trial and error.
Posted : 20/02/2024 11:18 am
dc1988 and dc1988 reacted
There is an element of trial and error also usually. TFTuned calculator is an ok starting point but there can be some quite big discrepancies
Posted : 20/02/2024 11:25 am
https://j-techsuspension.co.uk/pages/spring-calc
I used this, then i paid them £5 to work it out for me. They then give you a £5 credit if you buy the spring from them.
Posted : 20/02/2024 11:26 am
I think I used the tf tuned calculator for my sentinel and ended up way out. But on the Bird Aether I had it was only one weight out I think.
It also depends on the shock imo - some of them have heavier damping as standard than others. I think my Cane Creek Kitsuma is lighter damped and so I’ve ended up using a significantly heavier spring than tf tuned’s calculator suggested. But people of a similar weight / same bike as me with an Ohlins or EXT shock have got away with a lighter spring.
Posted : 20/02/2024 11:38 am
Tftuned calculator
Posted : 20/02/2024 11:57 am
Mention the bike, the shock and your weight in your post and listen to what others say from here?
Posted : 20/02/2024 12:07 pm
kelvin and kelvin reacted
My bike came with a 500 which seemed a bit too soggy, tf and j tech calculators both said to go even lower. In the end I went for a spindex 500-550, 520 is nice for local stuff and have the ability to add a bit more for dyfi and the alps etc
Posted : 20/02/2024 12:26 pm
Not all 500lb springs from different manufacturers are the same either, so bear this in mind if picking up a range.
Nukeproof springs are a reasonable weight and suit a lot of shocks with the supplied shins.
Posted : 20/02/2024 1:36 pm
I stuffed my info into the TFtuned calculator and bought one spring either side of its recommendation as well as the weight it suggested. That way if I loose or gain weight or want to tune it to perform a certain way I can. Plus I got to play about with lots of springs.
Posted : 20/02/2024 1:43 pm
