So I love my Sentinel - but I’m tempted to try a coil shock on it rather than the Float X air shock that’s on there now.
I had a 2021 DHX2 Factory on my last bike and it was ace - it was less inclined to wallow through the mid section before ramping up hard at the end.
Ideally I’d get a Cane Creek db coil il but they don’t make the trunnion mount version long enough (need a 205x62.5 trunnion shock).
Wondering about a Dvo Jade or Jade X as they’re just under £400. Any experiences of these?
I’m not wild about the idea of a Bomber CR as they’re pretty heavy and don’t have a climb switch. Anything I’m missing in a similar price range?
I’ve got a RS super deluxe coil on my V1 with cascade link so fairly similar to the V2, can’t fault it. Way better than the custom tuned dpx2 for grip and plenty of support. I’ve got an ext coil for it to lighten it up a bit, j tech do a spacer to allow you to run the shorter spring.
I’ve got a DVO Jade X. It was on my Rail and it’s now on my Kenevo SL. It’s very good, but to be honest I’m comparing it with boggo OEM air shocks.
DVO Jade X is a decent shock, you probably want to get a progressive spring for it as well, as the actual shock doesn't come with a spring, so factor that in to the price.
With the budget in mind i'm going to go against your first thoughts and say the Bomber CR is lovely... a lovely lovely shock. I think bikes climb well enough these days that a lockout/climb switch is less of an issue than it once was and the CR comes in at a price that's hard to argue with. It's simple, effective and well priced, as well as being superbly plush.
Yeah it's heavy though.
My recommendation would be a Rockshox superdeluxe coil from Jtech.
When you get it from Jtech you'll get a custom tuned for your bikes leverage rate/weight/riding etc. I struggled with my Super deluxe on my Highlander until I spoke to James at Jtech, .and after a spring calculation confirmed it was the shock tune. It completely transformed the bike from a harsh mess.
Not only that, after riding it for a month or so I felt it was too soft, so James sent me a couple of EXT springs to play with...and went up half a spring rate, now running a 475lbs EXT spring with spacer and really happy. Great service.
There is a really good shock under the stock RS tunes on those super deluxes.
Saw the title and came here to suggest the Bomber CR. My current fantasy bike setup is a Sentinel with a CR with an Avalanche tune to it. The CR is the shock Craig reccomends as the best starting point. Most of the "extra" weight is on the spring which can and likely will be changed at some point anyway.
Even on my coil spring 6 pack in 2005, I never wanted a lock out.
Thanks for all the comments so far.
I’d ruled out the DHX2 as being too expensive. The super deluxe I’d thought about but it uses a 38mm coil and the Rockshox springs are really quite heavy.
I’d kind of categorised the Bomber cr in the heavy / limited adjustment box too. Looking again at weights actually it doesn’t look too bad - maybe with a custom tune to my weight / bike it could be an option.
The cane creek / dvo options could use a cane creek Valt which is quite light - the Fox sls spring is even lighter but too spendy.
The Jade X was in the list as it has bladder pressure adjustment which might be nice, takes a 36.5mm spring, doesn’t cost too much and I thought the middle position of the 3 position lock out thing might work nicely when on flow trails where you don’t want the full sensitivity that you would on full on tech trails.
So maybe it does come down to Bomber vs Dvo Jade X.....
Just a thought - one of the posts above mentions a progressive spring. On my last bike (Aether 7) I just had a normal Valt spring - if the bike is ok for coil why would I need a progressive spring?
Simple answer is, the way the suspension reacts. More or less at different parts of the curve. Just because something is suited to a coil, doesn't mean it can't be better (or worse) with a progressive spring.
My coil was/is a standard type, not progressive, i didn't see a need to change that, but i think we're getting into absolute finite details of suspension here and something that very very few people would truly notice outside of confirmation bias after spending money.
For me i see it the same as the people who can notice the difference between 25 and 26psi in a tyre 🙂
You wouldn’t, progressive springs are a sticking plaster solution to bikes with linear suspension curves. Most bikes are past that now.
You want a fairly common size shock for that bike, I would be on Pinkbike for one of the new style DHX2’s. The old ones weren’t amazing, but the new ones are really good. I put mine on a par with an EXT/Push. £400 will get you a barely used one.
I did like my 2021 DHX2 but was thinking of 0% financing this shock tbh so looking at new ones.....
Those were my thoughts on progressive springs - that they were for bikes that weren’t really designed with coil shocks in mind.
On the tyre psi front I notice the difference in say 25 psi to 18 psi when I’m looking for a grip on steep / wet / rooty slow tech - but I very much doubt I’m noticing a couple of psi different. I do mostly set my tyres to the same psi for most rides using a digital gauge though for consistency.
Slight tangent about progressive springs if I may. I'm having a brain fart and have myself trapped down a particular line of thought.
If a spring has two spring rates in different ends (the simplest form of progressive), doesn't that just work like springs in series? Unless the rates are so different that one end is coil bound before the other has finished its travel? If so, doesn't the softer end frequently go coil bound and does this have a fatigue issue on the spring?
you'll maybe be limited then as i don't think J-tech or TFT do 0%.
Tredz do and have shocks..
I’ve had my Bomber CR for over 2 years (on a Bird AM9) and I can highly recommend it. TF Tuned tweaked mine to suit my weight as well which made a good shock even better.
you’ll maybe be limited then as i don’t think J-tech or TFT do 0%.
I could always stick it on a 0% credit card if need be to open the options up a bit. A shock with a custom ish tune would be preferable to just vanilla out the box that may or may not suit me / the bike.
Have just ordered an ohlins for my scout from tf for the same reasons.
The x2 feels like crap compared to the fork (ohlins on the front).
They might do 0% and they had shocks in stock last week
The Nukeproof lightweight springs fit the RS Deluxe coil if it helps, none of the standard steel springs are light but more options secondhand for the Fox/Marzocchi etc
Looking again at the Jade X I think it’s less adjustable than I thought - looks like there isn’t lsc in the open position - it’s just a 3 position lsc lever. Might rule that one out then.
Leaves the Bomber CR and perhaps the Jade (not X) - neither have a climb switch so I think a custom tune would be the best option on both of those.
Or maybe look at lighter springs for a super deluxe ultimate coil and try and find one in a sale.
If you liked the damped feel of Cane Creek shocks, consider the Kitsuma. I have ridden several DB coils and the Inline coil - and the full fat version is much better IMO.
You can probably pick up a Valt spring cheap off PB buy/sell.
I’d love a Kitsuma or DHX2 factory but they’re getting a bit spendy for me.
I got lucky and found a literally new Ohlins TTX22 on eBay for £480 (turned out to be from a shop, I don’t know why they were selling it like that and I didn’t ask given the price!) and a used spring for another £60. I sent it to JTech for a tune which cost another ~£80 if I’m remembering right.
A few observations:
1. They only bumped the compression tune up by one “step” so the factory tune on the TTX was quite close to what the Sentinel needs anyway.
2. After the tune, JTech suggested running a fair few more clicks of compression damping than I had before. In the end the main change was a decent chunk more compression and similar feeling rebound.
3. With this tune I never never feel the need to hit the climb switch, I get great traction over rocks and roots, plenty of support to push into and plenty of pop off of features. What I’m saying is that you may not need the climb switch if you get it custom tuned.
4. I’m using a regular linear coil, I don’t have any problem with blowing through travel or bottoming out, I don’t think it needs a progressive coil.
5. Coming from an X2 and using the Ohlins light weight coil I ended up only adding about 80g in weight.
One other thing to keep in mind is that I’ve seen people struggle for reservoir clearance with the Bomber CR and also the Ext Storia in smaller sized Sentinel frames so maybe mount it up without a spring to check before spending on a tune.
Whatever you decide I would 100% recommend a coil on the Sentinel, it has made a big improvement to an already great bike.
Here's a 4 ride old Ohlins for £450. You need the 65mm stroke with a reducer shim that comes in the box.
And here is the same seller as I got mine from selling a 60mm stroke version for £495 if you can face a slight travel reduction. DM me if you're interested and I'll tell you which shop they are from.
There are lots of Sentinel-tuned shocks on the German sites, you can buy your own spring instead of RS ones
I wouldn't say that, it's a bit like saying air shocks are a sticking plaster for linear suspension (Single Pivot, etc) or slightly progressive (some 4-bars, horst, etc), many designs still have a less progressive curve, especially in the bottom third of the travel, so having a progressive spring can assist in reducing bottoming out or blowing through the travel, but again, it's about what you're doing with the bike.
If a spring has two spring rates in different ends (the simplest form of progressive), doesn’t that just work like springs in series? Unless the rates are so different that one end is coil bound before the other has finished its travel? If so, doesn’t the softer end frequently go coil bound and does this have a fatigue issue on the spring?
Not quite, especially in this world, you could mimic it, but it would be a bit of work, probably why if they use more than one spring in suspension, it tends to be in parallel, i.e. a spring in a spring.
I don't profess to fully understand how they interact with various suspension kinematics, but progressive springs can be transformative on the right bikes.
Nothing wrong with a nice sticking plaster if it saves buying a new frame.
You'd hope the current Sentinel wouldn't need one though.
You’d hope the current Sentinel wouldn’t need one though.
IMO it doesn't.
Thanks - but unfortunately they’re all for the last gen Sentinel. The bike changed in 2022 so it takes a longer stroke shock now.
@appltn - thanks for your comments - the Ohlins looks very nice on your bike. I definitely want to keep the 150mm travel at the rear - I’m currently on a 150mm travel Lyrik Ultimate at the front as it’s what I already had. Going to get a 160mm airspring for it at some point. I was worried when I impulse bought the Frameset I was going to find a full 29er too much / would dumb down the trail and it was also longer travel than I was after (was thinking Aether 9 / NP Reactor really) - but I’ve been very pleasantly surprised - it’s been awesome in every way really.
Can you explain further? I'm not asking to be argumentative, if I'm missing something, I'd like to learn.
The video about seems to show what I was thinking in that the softer, closer wound coils work first, then when bound, the rest of the coils come in. The same effect you'd get from a shorter spring inside a longer spring.
I hadn’t considered clearance would be an issue for a shock piggyback - do you mean vs the bottle or something else?
This is the bike - it’s a medium alloy Sentinel:
[url= https://i.postimg.cc/RhpygCtY/3-D85-D23-D-97-FD-443-B-BC2-C-22-F536659-E21.jp g" target="_blank">https://i.postimg.cc/RhpygCtY/3-D85-D23-D-97-FD-443-B-BC2-C-22-F536659-E21.jp g"/> [/img][/url]
[url= https://i.postimg.cc/L67GfX2Y/663-E4314-F740-4772-8640-FE1-F9-A66879-D.jp g" target="_blank">https://i.postimg.cc/L67GfX2Y/663-E4314-F740-4772-8640-FE1-F9-A66879-D.jp g"/> [/img][/url]
Although coil springs don’t ramp up at the end like air springs, they also don’t have a falling rate near the middle of the travel. Bigger negative springs help reduce that dip but hard to avoid.
The Bomber CR is a bigger external reservoir than yours, but only the context of down and out, so will be fine on your from what i can see there.
I’ve got an ohlins coil on my medium carbon sentinel and clearance is fine. I didn’t like the x2 it came with, it just felt harsh I thought.
Luckily I got pointed in the direction of those bargain ohlins coil shocks! They are 65mm stroke but come with the spacer in the box. It’s transformed the bike, come have a go on mine at nibley joe! Once my cracked rib is healed that is!
I think I would buy the 60mm stroke ohlins coil and get the stroke length changed. Imagine tf wouldn’t charge too much? Quick call would soon work that out! And through eBay mean PayPal credit or credit card!
That sounds good - let me know when you’re fixed! I just must not like the carbon frame as I can’t justify buying one even if it is a few lbs lighter - just need to keep making myself lighter / fitter to compensate.
Looking around at other forums, it seems there may be concerns over some piggyback reservoirs clashing with certain frames,/sizes at full bottom out.
Don't know why I'm looking, I don't own a sentinel v2.
I hadn’t considered clearance would be an issue for a shock piggyback – do you mean vs the bottle or something else?
The issue can be with the reservoir contacting the downtube.
There's a guy on the pinkbike Sentinel thread who had all kinds of trouble getting an Ext Storia to fit his size M Sentinel.
Clearance problem with cascade link.
Clearance problem with stock link.
Eventually resolved with a revalved e-storia
I'm not saying it will be a problem for you at all, just check it before hucking to flat and putting a ding in your frame! Also I wonder if the alloy frame has smaller tubes and therefore more clearance than the carbon.
Have you looked for a 2022 Fox DHX?
Fox replaced Bomber CR with a new Float X. I was going to sell it on and buy a DHX2 & rang a Cyclinic to verify their one in stock was right for my Banshee. They said the DHX was a beefier shock for trunnion mount bikes. They also said give the Float X a go & I'm impressed, a lot better than the original X2. Talked themselves out of a sale.
Can you explain further? I’m not asking to be argumentative, if I’m missing something, I’d like to learn.
The video about seems to show what I was thinking in that the softer, closer wound coils work first, then when bound, the rest of the coils come in. The same effect you’d get from a shorter spring inside a longer spring.
Think it's just lost in translation, i'm pretty much saying the same thing, i.e. on a progressive spring you can do what the guy says, change distances, material, density, etc to get the progression, you could mimic this with series or parallel spring layout, i think that's where i was focusing on with your previous response, thinking you were putting a spring series as an alternative.
@argee
Now I'm making my head hurt.
Is a progressive spring similar to series or parallel springs?
If you made a progressive stack of spring washers, a single against two cupped together, against 3 cupped together, that would be progressive but logic says they would be in series. However, the point we agreed above about a string in a spring is clearly in parallel. It can't be both.
Edit. Or can it? With a shorter spring inside a longer one, initial movement is just the longer springs rate. Once the second spring comes into contact, there's two in parallel, which can be resolved to a single spring. That's then the same as two springs in series (isn't it?), Which again, could be resolved to a single spring.
The more a spin around with this, the more I convince myself that progressivity is due to the isolation of coils as the come into contact with the adjacent coil. (Become coil bound)
@Onzadog, yeah, it's getting way too sciency now, i thought i'd left that stuff back at uni!
I just see series/parallel having the issue of independence and influence from other forces, the headscratching one is just the reason i say mimic, by length, density, material, etc, etc, it's just a mechanical system in the end.
But, it does make progressive springs a way more desirable alternative ;o)
Yeah, must be twenty years since I last did anything with my mech eng degree. Hence the head scratching.
If you'd like he DB coil IL have you considered asking TF if they can lengthen one to fit?
Got a Jade X with a progressive spring on my 2019 Patrol - I reccomend!
