coed y brenin... to...
[Closed] coed y brenin... too cold?
[#5792982]
going to coed y brenin Friday with a big group from Wolverhampton. will it still b a good ride this time of year? unless we get 2000inches of snow? any1 been there lately
Posted : 22/12/2013 9:20 pm
As you say, unless it's sub zero for a while, I'd expect it to ride as well as any time of year.
Posted : 22/12/2013 9:24 pm
Thanks for the warning.
I'll be sure to avoid CyB on Friday.
Posted : 22/12/2013 9:30 pm
Too cold? Are you joking?
Posted : 22/12/2013 9:31 pm
 iolo
It's never too cold. The only thing to be careful of I'd the armoured stream crossings bthe water dragged up from coming out of the streams freeze and can be quite interesting.
Posted : 22/12/2013 9:38 pm
Because CyB is that much further nortj than Wolverhampton...? 😕
Posted : 22/12/2013 9:42 pm
not much further north but lot closer to the coast. suppose if we ride really close together we can be warmer. or go faster?
Posted : 22/12/2013 9:49 pm
Closer to the coast should be less cold on account of the Gulf Stream. A discussion point between you and your friends as you ride around the Beast perhaps...?
UK really isn't cold enough to consider boycotting a ride on temperature grounds.
Posted : 22/12/2013 10:05 pm
But the extreme elevation could create death-zone type conditions at this time of year, surely?
Or is it just a question of tyres?
http://www.metoffice.gov.uk/loutdoor/mountainsafety/snowdonia/snowdonia_latest_pressure.html
Posted : 22/12/2013 10:11 pm
Just to make it clear I'll be avoiding it so that i don't have to bump into you Wolvo types.
Nothing to do with the weather.
Posted : 22/12/2013 10:14 pm
Yes.
Not going to happen.
Yes.
Posted : 22/12/2013 10:18 pm
It's still shorts weather in the UK, even in Wales. Okay Scotland is colder, but they'd not only be in shorts but t-shirts too. Sorry, string vest 😛
I'd be more concerned about being soaking wet and/or muddy. Doesn't stop a great ride, but just be sure to be prepared. Spare clothes, change for showers (and hope the centre is open), etc.
Posted : 22/12/2013 10:24 pm
It's good any time of the Year
2000inches of snow?
No
2000inches of Water?
Possibly 😯
Just get out and ride....
Posted : 22/12/2013 10:30 pm
It is a weather proof ride. Rain snow fog sleet wind and even on rare occassioins mild sunshine don't seem to get in the way.
Yow a bostin time!
Posted : 23/12/2013 9:05 am
I'll be riding my 650b so should be ok, not sure if the others will survive
Posted : 23/12/2013 9:24 am
"not much further north but lot closer to the coast. suppose if we ride really close together we can be warmer. or go faster?"
If you stop every 15-20 minutes and all have a big group hug then that will keep you warm, might want to stay off the trail for that though as normal bikers might just be riding normally in the normal weather.
Posted : 23/12/2013 9:38 am
 DT78
Cold is not a problem, reckon you should take kayaks rather than bikes if the forecast is accurate
Posted : 23/12/2013 9:44 am
Sod the weather, beware the locals. They hang the English 'round them parts don't you know...?
Plus, being from Wolverhampton, they may be extra hostile to you on 'accent' grounds...
Posted : 23/12/2013 1:40 pm
Be drier riding in the canal & they don't have Tipton made scratchings in Wales
Posted : 23/12/2013 1:48 pm
ah, so even cold trails will come alive
Posted : 23/12/2013 1:52 pm
More help. And less willy-waving:
Yes, but it will be a bit cold in places, probably not more so than anywhere else > 1000ft alt at this time of year, but it may be a bit wetter. Being Wales.
It rides well and is fast in all conditions, so I wouldn't worry about it too much. Just remember that high parts of The Beast can be quite exposed to the elements, so a large group will need warm things.
Two thousand inches of snow would be a worry, so I would avoid it then. We have just had nearly that amount of rain and high-velocity air molecules, so things might be a bit manky. But like I said CyB is pretty robust to the elements
No, sorry can't help you there. Been off the bike for 5 weeks now with a broken sternum. But I do live just down the road and have probably been round The Beast ~20 times in the last 3 years, so I know it reasonably well..
Posted : 23/12/2013 4:06 pm
maybe us wton folk will scare the rain away. and every1 else by the sound of it. we aint that bad. just a bit silly from all the Cannock slop
Posted : 24/12/2013 4:42 pm
What,they let you Glasgows use OUR Chase as well ????
Posted : 24/12/2013 4:47 pm
* is ashamed*
Posted : 24/12/2013 4:48 pm
You will only be cold if you dont have the right gear.
Posted : 24/12/2013 4:53 pm
It may be colder because of the altitude perhaps??
Posted : 24/12/2013 8:02 pm
also theres a rumour going round that single speed stu likes men.
Posted : 24/12/2013 8:03 pm
CYB Visitor Centre (139m) is lower altitude wise compared to Llandegla Visitors Centre (359m) so so will be a few degrees warmer, at no point does CYB reach the heights of Degla's lowest point.
Friday looks like Armageddon Round 2 so Waterproofs will be handy and staying within the trees gives you that bit more shelter, the exposed sections if you were doing Abel on the Dragon's Back section would be a bit tricky if it's blowing a gale.
Posted : 24/12/2013 8:46 pm
