who makes decent ones, or are they all much the same
what makes a good one good anyway ?
(not expecting to use all that often so cost of cannisters isn't a massive deal - or maybe they're all the same design/fitting and I can use any?)
Depends. A lot of the head valve only units are exactly the same but with different branding.
For example, I have a Sram one that looks the same as Genuine Innovations one. They all seem to do essentially do the same thing.
[img] http://i.imgur.com/EgU2eBp.jp g" target="_blank">
http://i.imgur.com/EgU2eBp.jp g"/> [/img]
Depending on usage, you'll be looking at 16g threaded carts, which get cheaper the more you buy. Don't get branded ones, as they are a rip off. Although the [url= http://www.wiggle.co.uk/lifeline-essential-co2-inflator-cartridges-pack-of-6/ ]Lifeline ones on Wiggle[/url] aren't too bad at a tenner for 6, but you usually get [url= http://www.ebay.co.uk/itm/16g-gram-CO2-Threaded-Cartridges-Pump-Inflators-Bike-Cycle-tyre-pump-Gas-C02-/301289302704?pt=UK_SportsLeisure_Cycling_BikeLocks_SR&var=&hash=item46263deab0 ]10 for £12 on eBay.[/url]
Ta Jamie
no "trigger" on the head part ? they just jizz the whole lot at once ?
[url= http://www.tyreinflators.co.uk/index.php?act=viewProd&productId=256&category=2 ]cheap CO2 here[/url]
You screw it in one way to pierce the top, then backing it off works as your release valve.
Some more info:
Really rate my Topeak CO2bra. Never let me down and neatly packaged with Levers.
Bought an Unich the other day, really like it. Bonus is it has a botton on the top to control airflow.
