Clunky Pikes
[Closed] Clunky Pikes
[#600493]
My 4 week old Pike Airs (got from CRC) have started to make a clunky/knocking noise when going over small bumps. Its in the initial 5-10mm of travel and can be felt when stationary also.
They were fine up until a couple of rides ago and are getting worse.
Any ideas before i think about sending to TF?
cheers
will
Posted : 03/06/2009 9:27 am
Are they U-Turn? Check the travel adjust isn't 'between clicks' - mine have been like this a couple of times and made a nasty knocking sound.
Posted : 03/06/2009 9:32 am
Although I also have the Pike Air from CRC and haven't yet experienced what you describe, I did have a set of Revs which sound like they had a similar knocking and put it down to this from TFT site...
[i]My U-Turn air fork knocks slightly, what is this?
There’s play in the travel adjust helix. A small amount of play is necessary because if it was tight you wouldn’t be able to turn it, however this can cause a knock. During service, we reduce this as much as possible but it can never be completely eliminated. [/i]
I'd give TFT a ring
Posted : 03/06/2009 9:34 am
Send 'em back to CRC and tell them they're broken?
Posted : 03/06/2009 9:35 am
they are U turn so i will check. Seems to make the noise across the travel range but is less when travel is less
will
Posted : 03/06/2009 9:36 am
my coil pikes never did it
Posted : 03/06/2009 9:37 am
 Rich
My coil Pikes do it sometimes.
If I turn the u-turn in or out a couple of turns it goes, so I just do that. Just seems to be when the forks are a certain length, it is worse when they are not at full travel.
Posted : 03/06/2009 10:03 am
My new coil U-turn Pikes make the noise you describe. Interesting about the U-turn being the cause, I'll have a fiddle..
Posted : 03/06/2009 10:05 am
 Rich
Well my u-turn broke today, dial just spun with no movement from the legs.
hhm.
Posted : 03/06/2009 2:56 pm
