When I started riding in the Hampshire Alps (Lordswood) I had loads of silly crashes often caused by not being able to clip out in time if a wheel slipped on one of the occasional roots, or not being able to get clipped back in after avoiding the aforementioned root.
Previously had 20 years on clip less pedals (big hand grenade style DX back in the day then Time for the bulk of it) but moved to flat's with 5.10 shoes. (Currently Straitline on one bike, Superstar Nano on another)
Took maybe a few weeks to get used to it all of the time but now I just don't notice. I've happily done 100km forest track bashing rides as well as Enduro races etc...
Had one or two shin gouging incidents but no more.
I was taught both heels down when doing a skills course & now I'm used to it I reckon it gives more control & I don't find the need to scoop the rear wheel as I use my weight shift to allow the back wheel up when needed. It makes sense when you try it properly.
I had been using SPDs since 95 up until a couple of months back. I was fairly happy on spds in terms of riding but was getting really bad foot pain (even with the larger cage type spds) so borrowed some flats to see if that helped and had no pain at all.
The 1st ride was mixed as I had a couple of moments where my feet came off the pedals as I was still trying to pull up to get over obstacles but loved the feeling in corners. I stuck with it to avoid getting the foot pain again and have worked on my technique a bit and now love riding flats especially now the weather has turned as I am a lot more comfortable with the bike sliding, before I'd have been looking to get a foot unclipped now I know I can dab if I need to.
I would definitely get the best shoes you can afford as the difference in grip between the trainers I used when trialling them and the 5:10s is huge.
Probably the key point here, if you are comfortable getting in and out of SPD's then that part of it doesn't really come into play. (a year racing DH on HT's on small pedals and XC shoes kind of sorted that one out for me)
If you do the technique stuff right in clips you can do all the same stuff, just need to think a little more - then when you're knackered and don't want to think you can fall back on the clips. Win Win.
Has someone really linked to bikejames.com on that previous page? One of the most notorious cycling quacks on the internet? People were linking to him in around 2003 on here and his research wasn't credible then.
As for the OP, you might like them, you might not. I run flats occasionally, for example in the Alps or for street and park riding, not that I do much of it anymore. I definitely don't like them as much as SPDs, by a long way. If you like them, great, but if you don't then you don't have to feel pressured by the cool kids to stick with them. It's no slur against your skills to use clips.
Theres a very good reason every XC pro rides clipped in.
Christ, not this again..... I suspect the OP isn't planning on being a 'XC pro' any time soon...
I went to flats not to improve my technique, not to appear cool....
But because after 12 hours of the puffer my knee was in bits (since had an op on it, so it might be okay now!) and also because I was fed up off my feet being blocks of ice, and despite spending a small fortune on various winter spd boots/shoes, they all had the same fundamental flaw. A big damn brass heat sucker on the bottom.
I don't why people hate him so much. For me nothing has improved my riding more than his advice and programs. The stuff he says is interesting actually works and he backs it up with studies.
dmck16 - Member
You can angle your pedals in a sort of cradle, with your leading foot toe-up and your rear foot toe-down. This allows you to push against each pedal for either a little extra security or to move the bike with your feet. If that makes sense?jairaj - Member
Thats not the technique that I was taught or found it works for me. Both heels down is what I useTry scooping your back wheel up with dropped heels...
You only rock your back toe down to lift the back wheel up. Heels down the rest of the time to keep planted going through rough stuff.
blackmountainsrider - MemberI wouldn't bother. It's a myth that flats give you a better technique. It's just a different technique.
Well. It's not that simple is it? The key techniques that make flats work are also valuable for spds. The difference is, flats make you develop those techniques or you'll crash your brains out, SPDs don't. It's totally possible to learn the exact same techniques on SPDs which is why some people try flats and find it's just easy, whereas others find it a challenge.
Ironically, if you jump on flats and it feels horrible, you probably have more to gain from sticking with it. When it comes right down to it it's all just "moving with the bike" and that's valuable regardless of pedals.
I went to flats after many years clipless to, was the best thing I did when I moved sooth to the Lakes. Riding on my own clipped in - and usually at very quiet times on the trails - I was finding The Fear seeping in on anything technical. My ability to ride went out the window and I started mincing or walking bits that really weren't that hard.
Switched to flats and everything was good in the world again 🙂
Sounds like a lot of people never got to grips with clips. It never crosses my mind that I might not get out of the clips if I needed to. On the bales and crashes I've had getting out of my bike has never been a problem. I can get out instantly without even thinking. But ultimately it doesn't matter - whatever works for you. I feel more confident and secure clipped in, but that's just me. I'm conscious of proper technique and employ it to the best of my ability - I don't need the additional motivation of knowing that if I don't employ proper technique it's going to end up with a crash or scraped and bloodied shins, and if the answer is to wear more pads, then I'm not interested. The proper technique works so benefits riders whatever pedals they're using.
But it's all good, ride whatever makes you feel better. If it feels better, it is better.
@paton, yes, i agree, not really feasible to pull up at any sensible cadence. Only really works when climbing something horrifically steep and cadence has bogged right down.
If you are pulling up with your trail leg are surely you cannot be pushing down as hard with you lead leg.
That wasn't really the point. I was just objecting to @idiotdogbrain being an idiotdogbrain......
The point was that [i]if[/i] the OP has a nice smooth round pedalling style he [i]may[/i] find it irritating having his unweighted foot come off all the time.
And since the topic is titled "what to expect", it seems quite logical it should be mentioned.
Don't know the answer to that - you'd need to ask someone into biomechanics or something I guess. It seems to work, although as I say, not something that gets used very often.
I've just done this in the last two weeks. Been riding properly for 17 years. Learnt to ride trials and dirt on flats for the first few years then went to clips for xc and 'enduro' I still hit relatively large doubles, drop offs etc clipped in.I thought I would never entertain flats on an mtb for general riding. However I tried them just for a laugh last week. Now I have a set of 510s and am hooning around even more sideways before. Tried them on the hardtail at woburn sands and hit nearly all but the longest of doubles.
What I found was on the slash hitting big bumps the suspension would deal with it better and my weight stays rearward. On the ht ( a genesis latitude) big bumps and drops I had to concentrate a bit more to really shift my weight and drop my heels as I felt at high speeds I was going more over the bars as my feet lifted a bit.
One main benefit is that I'm finding myself faster into corners and through them. I was never the type to unclip and motocross style it through corners. I still keep my feet planted even when both wheels are sliding. However in my head I feel a tiny bit more confident that I could be able to dab and therefore I'm committing more initially into them.
Hope that helps.
The point was that if the OP has a nice smooth round pedalling style he may find it irritating having his unweighted foot come off all the time.
I don't understand why your/his foot is/would be coming off all the time. If you cannot spin your pedals round without your feet being strapped to them that indicates bad pedaling technique.
technique.
I found my front foot would lift of the forward pedal, this would happen if the rear wheel got hung up a bit on steep tecnical climbs when my cadence dropped. With spd's I could just pull my rear pedal through. Over time maybe I would have adapted to this, but for me I thought why bother, get the spd's back on and be happy 😀
Care to explain?
It seems perfectly normal that the foot that's unweighted comes off the pedal very easily, particularly noticeable around 8-10pm as there should be virtually no pressure on the pedal there, and at around 12pm as you want to start applying power over the top.
If this wasn't the case, then do you care to explain exactly why toe clips and then clipless systems were invented in the first place?
Yup, I definitely found that- on high power pedalling I didn't have an issue but in steadier pedalling there's very little weight on the foot at some points. (and the less, the better) I can sustain a nice effortless spin on flats but it takes more thought and at best it probably isn't quite as effective as I was with spds. But in practice, I don't really try, because it's a hassle, whereas with spds it's effortless.
I think people visualise/rationalise pedalling in different ways and there's a bit of a tendancy to oversimplify (like obsessing with pulling up, frinstance, or obsession with dabbing) Bottom line is it's a good idea to get good at both then decide which one you [i]like[/i].
i made this change (yonks ago) and quickly realized that I'd happily trade any speed advantage with SPDs for the extra fun and freedom I felt on singletrack etc.
I went from toeclips to SPDs to flats and I never enjoyed riding more than with flats 🙂
Your trail leg is not moving with your pedal. From you description of what happens when you ride flats You are lifting your foot off the pedal instead of unweighting it and letting the drive from you lead leg return it to the top of the stroke. That would suggest that when clipped in you are pulling up on the back stroke which has been shown to be very inefficent.
That is not what the pros do. they unweight instead of pulling up.
Late to the party (as ever) but although I always reckoned that I could get a foot out of an spd pedal fast enough for a saving dab on slow, techy stuff, I realised that after trying flats for a few months I could do it a lot faster with flats and also, equally as importantly, get a foot back on the pedal instantly.
Also, I could just jump off the bike if things turned to shit.
The rockier and more potentially damaging the riding, the more I noticed the advantage. Whether it's just a psychological thing or not I can't say
There has to a reason that 99% of those alpine "Vertriding" guys use flats, with the possible exception of Tobi Leonhardt - presumably because with the sort of exposure they experience a fraction of a second could be the difference between life or death?
This is my motivation for trying flats. I am too timid on tight steep, loose corners and would like to have the mental safety blanket of being able to dab quickly. This could be complete bllx, but worth trying I guess.
Exactly, and the very reason I use flats on my 34/18 SS hack; 120rpm on the road in flats soon showed up the lack of smoothness in my pedal stroke and helped me correct it. Second nature now, just like riding clipped in used to be.
At the end of the day, if there's any weaknesses in your pedalling and weighting technique, flats will show them up. If you fix them, the fix will transfer back to SPDs. If you choose not to fix them, that's up to you! It's all just grown adults arguing about pushbikes after all.. 😉
Pulling up on the pedals can, sometimes, be counterproductive
http://www.over40cyclist.com/correct-pedalling-technique-part-2/
If the itch needs scratching what are the best 5:10s for this time of year/all-year riding
Shimano AM41/AM7
Hugely psychological, there was an old pink bike on the topic which went along the lines that being able to throw a foot out easily made you rely on it more, being clipped meant you committed harder - the point comes where the dab etc. is there to compensate for something going wrong, if you know it's there you don't have to try as hard to corner/clean a section properly.
That said with the right pedal/shoe combo I'm happy to get out before I've finished thinking about it, there is a local trail section where if you get the launch wrong you're heading too close to the bank, on a few occasions I've found myself dabbing about knee height to correct then straight back on the pedals and clipped.
Also on pedals, the CB system lets you clip forwards, backwards and if you time it right straight down, most of the time once I've connected with the pedal (mallet) it's a case of nudge forward or back a little and I'm locked in.
teamhurtmore - MemberIf the itch needs scratching what are the best 5:10s for this time of year/all-year riding
Freerider Elements I think. It's not a great winter show tbh but most Five Tens are terrible winter shoes, the Element is OK
I know it is entirely psychological for me, but to be honest I don't really care! The added confidence is what I was looking for - after years on SPDs I was happy enough with being able to unclip without thinking about it, but there is always that odd occasion when it goes a bit wrong and doesn't release (very occasional granted!).
Most the problems I have riding stuff are in my head, anything that helps alleviate those is a good thing 🙂
I was a trials rider for many years, where the aim is to clean everything, so I don't think I suffer from "comfort dabbing" too much - however, there are times that with the best will in the world a dab, or even just stepping off, will save you from potential serious injury.
It's those moments that I've come to appreciste flats.
As someone mentioned previously, getting back on the pedal is a big benefit of flats over clips too. I had it fairly often in the past where I'd come unclipped and then I'm concentrating on trying to clip back rather than paying attention to the trail. Still see it occasionally when following other riders, so it wasn't just me.
Ultimately though I wouldn't have switched if it wasn't for the pain so I was quite content with clips. If you're curious then give it a go, it probably won't be as different as you might expect and the bits that are can be easily sorted.
Just give it a try to see if you like it, and if you've enough money to spend out on spensive pedals and special shoes do that too if it floats yer boat.. I seem to ride in an old pair of NB trainers most of the time at the moment, completely unhindered by their lack of MTB marketing
I learnt to ride when I was a kid and had never considered the thought of attaching myself to my bike in any way, I was always taught to kick the bike away from me in the event of a crash to minimise injury..
But after a lot of time hanging out with modern MTBers I noticed the prevalence of SPDs so I gave it a try for a few months..
Not for me I'm afraid.. I can see how SPDs could offer some advantages in the skills department to the inexperienced bike handler, but my style is fast and loose not do or die
Yunki, do you consider the likes of minnar, Steve peat and cedric gracia 'inexperienced' riders?
predictable..
No mate.. I just prefer flats cos that's what I'm used to after 40 years of riding them..
I suppose if you're a very skilled rider and looking for a few extra 10ths of a second here or there SPDs could maybe provide an advantage, although whether it's psychological or real at that level it would be hard to know... maybe it's just part of their sponsorship deal to market weird, expensive 'must have' gadgets?
like I said.. for me it's fast and loose not do or die
What was predictable? Someone pointing out you made a false statement about clipped riders being inexperienced?
I should add I think everyone should just ride what they like most. And if being clipped in makes you nervous on technical terrain or jumps etc it's clearly going to hold you back.
I think that there is a misconceptions though that using the fact you are clipped in to move your bike around is a bad technique. I'd say it's just different. I can definitely do bunny hops for instance, with flats, but it's just easier for me when im clipped in.
yeah exactly that....
both sides of our argument are fairly standard on here whenever this topic crops up
buy bent expensive shoes if you like, or don't... and make your own mind up about which is which
s'all marketing
If your technique isn't near perfect then riding flats will force you to improve it, which will benefit your riding on any pedal.
Generally clips are faster for racing for most riders but not for all. And in some conditions (when it's impossible not to exceed the limits of grip/balance so you have to frequently dab) then flats are quicker. The higher your skill level, the less often that will be - but that WC DH in Cairns was a good example of when even the pros are all quicker on flats.
pick a side, be a dick about it...
Flats [u]VS[/u] spds.
it's a pointless argument really. Find the pedals you like best, use them. As soon as you start to "justify" your choice in relation or competition to some other random person's choice, you've become a dick.
Don't be a dick.
Don't be a dick
spoilsport 🙁
pick a side, be a dick about it...Flats VS spds.
Don't be a dick.
this does seem like any sort of fun
Weirdly my feet feel more secure/planted on flats. On all the SPDs I've used there always appears to be some float, but I guess they aren't all like that.
I'm [i]probably[/i] never going to be World Champion though.
I am not gnar and have been quite happily riding around in SPDs for 10 years. When I bought a new bike (T130s) I was offered pedals so it seemed like a good chance to have a go on flats. It's not been an overnight success if I'm honest and my shins are testament to that but I'll keep with them for now because they're growing on me.
Over the last 2 months I've felt almost as attached to the bike as I ever did on SPDs and for wheels on the ground riding the ability to escape fractionally quicker has not gone unnoticed so in this scenario I prefer them.
Wheels in the air continues to be challenging though and mostly attributed to poor technique. I've relied heavily on the "SPD lift" for jumping which has been just fine for my riding but now no longer works. Each time I go out I get closer to a bunny hop and now that I've finally realised the importance of foot position on a flat pedal I've stopped slipping off them when lifting the rear wheel.
A new bike and new pedal type (with 5.10s) still makes me excited everytime I go out, I'm having to revisit my technique and suprisingly I don't mind; there's something nice about going back to basics by trying to jump twigs and puddles but I'm getting better every time and that makes me smile.
I made the switch about a year ago and have stuck with it - mostly as I felt myself being less confident when clipped in on technical sections after a couple of crashes. However, I haven't found it an easy transition, and after being off the bike for nearly a month after a DMR Vault shin-eating session I'd heartily recommend some decent pads! Better technique? I'm not convinced - just different as far as I can see - though with my minimal skill levels that's probably no real conclusion to draw! Try it, and see what you think - after all, its' what works for you in the end! 🙂
OP here with an update for those interested.
I bought a pair of five ten Maltese falcons (spd compatable) so I had a get out of jail card if I didn't enjoy riding flats.
Went for 15k/500m spin on my local bike trail centre and smashed the **** out of a load of PB's on strava
