Crud race guard vs SKS race blade 2?
23mm tyres, tight clearances on the frame.
The ability to remove easily for transport is a requirement.
Cruds are awful.
Not seen race blade 2 but I've been impressed with the originals.
The XL's are really quick to fit/remove but less coverage.
Cruds are terrible.
SKS everytime.
Cruds are dire. I'd go SKS.
Cruds fit fine and work if you're not ham-fisted and are stuck with tight clearances
Anybody used any with Planet X RT-58?
Cruds wouldn't fit my Planet X xls xc bike. Disc mounts stuffed it up.
SKS Raceblades are more robust and will stand up to more fitting/re-fitting.
Cruds work fine if you're not ham-fisted and follow the fitting instructions (and don't try to roll the bike along on its rear wheel with front wheel in the air)
This. Been using them moderately successfully for a few years now. They work well, but are rather fragile (toe overlap is another easy way to break them). Spare parts are easily available direct from Crud for not too much cash. Still the only thing that will fit my SC Roadster though, so that's one of the reasons I persevere.
I didn't like the old raceblades, but the raceblade 2 are different and look really sturdy whilst still being quick release.
£40 though. And I do have very tight clearance - I can't even run 25c tyres for instance.
You might be screwed either way then with anything that goes under the brake bridge / crown
If you have a brake bridge the Raceblade Longs - if you can find them - are worth a look. No more coverage for you but masses more for the poor buggers behind you. Also less finickity on subsequent removal and refitting because the mounts are in a fixed position.
Cruds here and happy with them, minimal clearances make them a better choice.
They're a bit wibbly and flexible, but pretty effective and adjustable with it... Lighter too aren't they?
Not sure how anyone could bollox the installation really, got mine back on for this winter inside of ten minutes...
Px pro carbon with 25mm tyres and sks race blades as my commuter. Can't complain, once set in the right position they are pretty quick to whip on and off. Having the bands set pretty tight has helped keep them in place.
Also have a look at the BBB slimguards
SKS but the ones that clip onto the clips on the wheels not the ones you clip tp your frame
Cruds were great when set up but a heavy breeze would make them rub*
* storage knocks actually bit i would only get them if i could easily store the bike with nothing near it and even then i still would not as they were faff faff and more faff. IIRC i ripped them off an binned them mid ride.
