Clicking/knocking s...
[Closed] Clicking/knocking sound from rear shock area
[#3364705]
Have noticed that something is clicking or knocking intermittently on my Bullit. The shock is a 5th Element. I have a replacement pivot bearing set I can try fitting as I think they need changing anyway (slight play when pull the back end with my hands), but is there anything else I need to look at whilst I've got the frame apart? I can't see any cracks but I'll check again.
This has been happening for over a month now, hasn't really got any worse or more frequent in that time and I think if it's gonna fall apart it would have by now given what I was riding on it..
Posted : 18/11/2011 12:00 pm
I'd check the shock bushes first, they are cheap as chips and a wear item. You would probably want to replace these when you do the bearings just so everything is new and shiny and they are only a quid or so each.
Which way are you getting the movement?
Posted : 18/11/2011 12:05 pm
Take the BB and pedals off, clean the threads, grease them and re-assemble, they can tick/creak if theyre dry or dirty.
Posted : 18/11/2011 12:09 pm
Here's how to check the bushes with the shock off the bike
With the shock on the bike
Bushes go more often than bearings
Posted : 18/11/2011 12:14 pm
I was doing it side to side. Just fitted the new bearings and tightened it all up. Seems fine now, no side to side play on the rear triangle and I haven't managed to get it to make the knocking noise yet 🙂 Dunno if it needed the new bearings but I've had them lying around for ages and may be selling it soon anyway!
Posted : 18/11/2011 8:41 pm
