Clicking on mates b...
[Closed] Clicking on mates bike
[#7894447]
My mates got a Planet X RT80 and asked me to Bob round and listen to a clicking on his bike. It's like a double click right underneath me. The harder the cranks are under pressure the worse it gets, especially when out if the saddle.
Any ideas?
Posted : 17/06/2016 10:02 am
Chain ring bolts?
Headset?
Loose cleats?
That'd be the 3 I look at first.
Posted : 17/06/2016 10:05 am
Chain - check the links for stiff or damaged links
Chainring loose/damaged
Pedals - loose
Front mech cable tapping the cranks as it goes round.
Does it happen with every rotation? With the crank in the same position?
Crank bolts are done up?
Poorly setup front mech?
Posted : 17/06/2016 10:25 am
Not cleats as it's happening when I pedal in my trainers now.
The bikes only done 150 miles so doubt it's wear and tear. I'll try the things suggested now. Cheers.
Posted : 17/06/2016 10:29 am
Yep it happens with every rotation and with the chain on any of the front 2 rings
Posted : 17/06/2016 10:33 am
I'd try the suggestions mentioned above and if they don't solve it - is it the bottom bracket? Is more grease needed?
Posted : 17/06/2016 10:36 am
Bearings in one of the pedals dried out?
Posted : 17/06/2016 11:01 am
Pedals or bb would be my first thought too.
Posted : 17/06/2016 11:04 am
I've just had this issue....take the rear quick release out, and clean and regrease it
We have a winner! Cheers stedlocks!
Posted : 17/06/2016 11:21 am
No worries ;0)
I only found out after I changed my BB and crankset, and virtually stripped the whole flipping thing and re greased.....happy to share my hard gotten knowledge! Spread it around too.....I reckon a good proportion of the reported pf30 BB creaks could be put down to the QR being dirty and dry.....
Posted : 17/06/2016 11:34 am
