A bit confused about this - Shimano suggest 5Nm; Time suggests a slightly eye-watering 35Nm - I suspect this latter might be a misprint as the bolts are too soft.
Anyone able to advise?
Andy
Posted : 19/03/2012 9:22 pm
I'd roll with 5nm. As you state the Time is probably a misprint of 3-5nm.
You'll probably pull the cleat through the sole if you attempt a 35nm setting... (Edit. tongue-in-cheek, before anyone gets tech on my arse)
Posted : 19/03/2012 9:25 pm
Thanks - I shall give it a go.
Andy
Posted : 19/03/2012 9:27 pm
Double post as broadband is playing the silly ar*e.
I've always done mine up "bastard" - after lots of heavy grease on the threads
Posted : 19/03/2012 9:28 pm
