Cleaning Lezyne bla...
[Closed] Cleaning Lezyne bladder
[#1630278]
I have a Lezyne back pack with a 3 litre bladder which needs a good clean (gone a bit mouldy). I have tried to detach the pipe from the bladder and the mouthpiece but it is pretty firmly attached. Has anyone had to do this? How much force can I apply? Will it be replaceable?
Or do I just bin it and get a new one?
Mike
Posted : 21/05/2010 12:03 pm
Miltons Sterilising Tablets, fill it up, leave it for 24 hours, mould gone! You may have to go it again, but it works very well.
Posted : 21/05/2010 12:10 pm
Haven't tried it with the Lezyne, but when my Camelbak tube needed force to remove I just put it in boiling water for a bit to soften it up.
Posted : 21/05/2010 12:14 pm
what milkie says plus one.i tend to make the solution fractionally stronger than it says and then rinse really,really well afterwards.
Posted : 21/05/2010 12:34 pm
Thanks guys.
The mouthpiece came off after application of hot water, the bladder end turned out to be threaded. Now for the Milton's fluid.
Mike
Posted : 21/05/2010 12:41 pm
