classic British tou...
[Closed] classic British tourers, anyone use one?
[#7088057]
I have a 1980s British Eagle (531ST) with old-school running gear - but haven't a clue how I plan to set it up yet, or how much to safely rag it off the beaten track . Looking for inspiration here before I head over to the Places With More Beards 😉
Posted : 25/05/2015 12:03 pm
Tourer and ragging off the beaten track ? Should be ok I rode a mid 90s Dawes Galaxy on the 3 peaks twice without breaking it .
Posted : 25/05/2015 12:24 pm
I think the tubing guages from those days can be noodly with a loaded front end, but they work!
Posted : 25/05/2015 12:27 pm
I just bought a 1960s Holdsworth Mistral frame. It was set up ss with forward facing sliding dropouts from new (SA 3 speed hub so i'm told). Frame builder local to me is going to replace the dropouts so I can run gears and cold set the frame so I can run 130mm modern hubs (currently 111).
531 is pretty forgiving so should be able to deal with a bit of rough stuff.
Posted : 25/05/2015 12:31 pm
Could be wrong but I think 531 ST (super tourist) frames have thicker gauge down tubes? However - the camping load I typically carry makes even my cromo M-Trax squirm at the back so thinking a more balanced load (ie more up front would help) but have no idea about front racks for bikes without midway braze-ons on the forks.
This thread needs dirty tourist pics...
Posted : 25/05/2015 12:53 pm
Well, after a first spin it feels bomproof leaping off kerbs so that's good enough for me, certainly moreso than the Dahon folder it replaced 🙂
Posted : 27/05/2015 12:14 pm
It's not that different from my mid nineties Roberts.
Steel touring bikes are super comfy, if needs be fit some wider tyres if you are planning on laden off road touring.
I thought mine would be irreplaceable until I bought a Vaya.
Boblo is your man, I think he has something similar.
Posted : 27/05/2015 12:44 pm
My Dad does about 20k miles a year all over the world on a 1990s build Mercian 531 tourer.
Steel is real 🙂
Posted : 27/05/2015 7:46 pm
I battered an 80s Holdsworth tourer round the long route of the real Leroica in Italy with no problem and thats bloomin rough in places
Posted : 27/05/2015 8:01 pm
Malvern Rider - Member
Being from that era (actually earlier 🙂 ) I did all my early mountain biking on a dropbar lugged lightweight racer.
The biggest problem was the alloy wheels were a lot more fragile - easily buckled. I got round that by using steel rims which looked really out of place - a bit like sticking Transit wheels on a Ferrari. So if you are using a more modern wheelset, especially a cyclocross, you're unlikely to have trouble.
The greatest fear was snapping the forks at the lower headrace, especially if your forks were lightweight. We used to stuff a bit of ash up the steerer tube to help prevent that.
The problem being that once your fork was stiffer, a decent impact would go into the frame and crease the top and down tube.
I managed to avoid ever damaging my bike, but it probably explains my wheels on the ground at all times riding style. 🙂
Posted : 27/05/2015 9:30 pm
Ah, the old Wiccan fork charm? But seriously, wahgwan?
Posted : 28/05/2015 8:37 am
