Clarks Brakes Quest...
[Closed] Clarks Brakes Question
[#9385792]
I bought a set of the Clarks M2 brakes. I need to shorten the hoses and as a result will probably need to bleed the system. Does anyone know if I can use the Shimano funnel thing? The bleed screw looks the same on a set of Shimano brakes.
If not, what kit should I use?
Posted : 16/06/2017 5:39 pm
Pretty sure I bled a friend's Clark brakes using my normal shimano connectors.
Posted : 16/06/2017 8:32 pm
Thanks Survivor. I'll give it a try.
Posted : 17/06/2017 1:26 am
I think so too. Although I never got my Clark's great so binned them, well, put in spares box.
Posted : 17/06/2017 7:08 am
I shortened mine without bleeding. Worth a try.
Posted : 17/06/2017 7:10 am
As above without bleeding but guess can hit lucky with any brakes shimano bleed kit according to article i read before buying
Posted : 17/06/2017 9:41 am
