Clarks anti-rust or...
[Closed] Clarks anti-rust or ptfe coated chains? Gimmick or not?
[#2593224]
I'm after a cheapish 8 speed chain for my commuter bike. Unfortunately I don't give my work bike quite the tlc it deserves, so was wondering if the anti-rust (£10) or garishly coloured PTFE coated (£14) Clarks chains from CRC are more resilient to neglect/general wear & tear?
Anyone tried them?
Posted : 24/03/2011 12:54 am
Bump for the bored/skiving work crowd
Posted : 24/03/2011 12:26 pm
I use a whipperman anti rust (SS) chain on my 456, been there 2.5 years and I have only oiled it because I thought I should, no rust is visible yet, but I've only cleaned it twice.
I reckon it works, but it's heavy.
Posted : 24/03/2011 3:17 pm
I had some a while ago where the outerplates were coated in blue PTFE, the blue stuff came off straight away and they looked a right dogs dinner, then rusted, then wore out alarmingly quickly.
They may have improved since. These were going cheap.
Posted : 24/03/2011 3:20 pm
You'll only get a rusty chain if you neglect it
Keep it lubed and it'll stay rust free, no need for any fancy coatings
Posted : 24/03/2011 3:25 pm
Thanks for pointing out the bleeding obvious Uplink, guess you didn't bother reading my original post...
Thanks ADH/Sacades. Looks like the PTFE one could be a waste of time, I assumed as much. Might give the anti-rust a go as it's only a tenner.
Posted : 24/03/2011 4:08 pm
do people really worry abou the weight of their chains?
Posted : 24/03/2011 4:16 pm
Al, people worry about the weight of everything, otherwise how do you explain the existence of Ti bolts?
Posted : 24/03/2011 4:29 pm
Indeed, they aren't even available in red!
Posted : 24/03/2011 4:31 pm
I don't care about the weight of the chain, it's on a 32lb hardtail which is set up for not having to be looked after - but it was noticable in comparision to a regular chain.
Posted : 24/03/2011 4:33 pm
