I am looking for a new headset for my Maverick frame which requires a "Campagnolo standard (45ºx45ºx42mm)" headset. I know its an inset i'm after but would anyone happen to know exactly which of the Chris King inset headsets I should be looking at.
Many thanks.
I'd have a look over mtbr - there's a fervent Maverick section on there that'll have the answer.
If it's the same as the ML7, the bearings just sit directly in the headtube - 'integrated headset I think - rather than using any sort of inset cup, so unless later models are different, I'm thinking the Chris King InSet won't work.
Its a ML7/5 Frame - should be the same as an ML7. Can anyone recommend a decent headset for it?
Tim at Sideways Cycles in Alsager should be able to help.
Ta - ill give Tim a buzz as I'm about due a rear shock service anyway.
don't be surprised if he doesn't answer - I think he's off on his hols.
Cane Creek do the 110 in that size. Probably the nicest available to fit.
The warranty on the 110 is pretty impressive so I think I have a winner - cheers for the help all.
Last time I looked into this the Chris King don't do one to fit the Maverick.
Iirc Cane Creek and FSA do the Campag fit headsets. There's 2 types of integrated, standard and campag fit, Maverick use the 45°x45° Campag.
