Chris King Headset-...
[Closed] Chris King Headset- Anyone ever service theirs?
[#2956470]
I bought my Chris King nothreadset back in 2005. Its been on two frames since then, but has never been serviced. partly because i didnt even consider that you needed to service it, and largely because its been perfect all this time. Now its starting to play up. feels a bit grabby. i am about to strip it down. I am trying to prepare myself for what i will find. is this just the end of the natural life of the headset? i notice that unlike say Hope, you cant seem to buy any spare bearing sets. so i spose if the bearing are ragged, then i will need to replace the whole thing.
Posted : 18/07/2011 12:28 pm
if it needs anything, just pop the seals with a stanley knife blade, then either repack with good grease if dry, or degrease and flush before repacking if particularly full of grit.
Posted : 18/07/2011 12:30 pm
what stoner said.
I've done that with mine. make sure you dry it properly after flushing.
Posted : 18/07/2011 12:39 pm
Did mine yesterday for the first time in 6 years as an annoying creak had developed - everything was still spot on so a quick wipe & a smidge more grease in each end & job's a good 'un.
Turns out the creak was actually from a shifter cable...... :-/
Posted : 18/07/2011 1:05 pm
thanks for the encouragement chaps. Even the Chris King website says [to paraphrase], pop the caps off, clean and re-grease.
I have done so, and currently all is well. The bearings didnt look too badly pitted, but were not perfect. all seems fine after the re-grease.
I was about to moan, why not proper sealed bearing? but then re-greasing every 6 years isn't too bad is it.
I am not entirely convinced how good those seals will be now.
Posted : 18/07/2011 7:59 pm
Pull it apart, clean it, grease it, put it back together (in the right order of course) all with the deft touch of a nimble fingered sweat shop sewer.
Posted : 18/07/2011 8:03 pm
 jedi
yep, do it. it's so easy i can do it
Posted : 18/07/2011 8:07 pm
tis done. 😀
Posted : 18/07/2011 8:13 pm
