Chinese mtb groupse...
[Closed] Chinese mtb groupsets
 boom
[#10511081]
Anyone got experience of buying/using Chinese groupsets, namely:
Sensah
G Ride
Ltwoo
Posted : 27/02/2019 10:51 pm
Have a bump mate.
Your thread got me looking at the above brands, mainly Sensah as Id never heard of these cheap Chinese groupset makers before!
Posted : 01/03/2019 2:14 am
Do Shimano / Sram not have a groupset to fit you budget?
However, please feel free to report on the performance ....
Posted : 01/03/2019 9:32 am
Not heard of them but the Microshift Advent 1x9 looks good, $125 but not sure if anywhere in the UK has them yet.
https://www.mbr.co.uk/news/microshift-advent-9-speed-384664
Posted : 01/03/2019 10:07 am
I saw that MS one, trouble is you can get 11 speed ‘groupsets’ (that’s a mech shifter and cassette for $125) for less...
Posted : 01/03/2019 10:22 am
 Andy
I was looking at that Advent stuff as I would like to try the rear cassette on my 1 x 9 bimble bike.
Posted : 01/03/2019 10:38 am
id quite like the advent gruppo too - i dont need loads of gears. but i am slack so a less sensitive setup is right up my street!
Posted : 01/03/2019 12:48 pm
SUNRACE CSM990 11t - 40t Mountain Bike Cassette 9 Speed for Shimano SRAM 425g
there is also this.
Posted : 01/03/2019 12:50 pm
Don't sunrace do a gear set now.....
Posted : 01/03/2019 8:18 pm
 Andy
Yeah that Sunrace is quite cheap, but 2 moar tooth with the Advent....
Posted : 01/03/2019 8:25 pm
Just to plug microshift, I've hit 11,000km on my 8 speed microshift groupset with no issues. Chain, cassette and crankset replaced (crankset by choice), but all else original. Still going strong.
Posted : 01/03/2019 8:54 pm
 irc
Microshift are Taiwan I believe rather than mainland PR of China. I have a pair of their 9 speed bar end shifters which I prefer to the Shimano version. Both work equally well but I like the more positive clicks on the Microshifts. A bit cheaper as well.
Posted : 01/03/2019 9:44 pm
 Andy
Yes thats it. Am using microshift bar shifters at the moment - its good stuff!
Posted : 01/03/2019 10:31 pm
 boom
Ok, I took the plunge and went for the Ltwoo AX 11 speed group
For €88 delivered I got:
11 spd Shifter, with cable
11 spd Rear mech
11-46 cassette
32t chainring
11 spd chain
Took about 3 weeks to arrive
Out of the box, all good, shifter is metal, rear mech looks fine
The only thing that threw me is that it comes with a goat link, which I hadn't copped when ordering
So this is basically a road mech
On fitting, the mech didn;t fit well to the goat link, had to add a washer to get a it to bolt up tight.
After this, fitted everything no problem
So how is it? When in 46 x 32, not good. Looks like there is too much play in the mech, meaning the chain is not traveling smoothly through the pulleys, rendering that gear almost unusable
Shifting through all other gears is fine
Other issue is that I have this on a 26er - and with the goat link the mech is waaaay to low/close to the ground in the high gears. i've no doubt it will be snapped off in no time
So- the verdict
Apart from the mech issue, the other bits all seem fine. So for €88 not bad, as those bits are worth that alone
I reckon I will keep the mech for a spare for my cx bike which is 1 x 11
I yet have to figure out which ratio the shifter is and whether its compatible with SRAM or Shimano XT for example - idea being that I'll just buy a NX or XT rear mech for the mtb and as I say keep the LTWOO mech as a spare for the cx
So all in all - I think the parts are decent, but the let down is that the mech is not a clutch mech designed specifically for mtb
Posted : 28/04/2019 3:49 pm
Microshift UK distributers told me mid-June for getting Advent into this country.
Posted : 28/04/2019 8:59 pm
I've used sunrace cassettes which actually look really good but it wasn't much cheaper than shimano. my main concerns are the quality of raw material and design.
Posted : 28/04/2019 9:50 pm
