Chinese light handl...
[Closed] Chinese light handlebar mounts
[#9634841]
I've been through 3 Chinese bike lights in the past decade.
One thing that annoys me is the handlebar mount which never seems tight enough and rotates during my road commute. Any suggestions of a better mount?
My light is a nitefighter bt21 with single screw hole underneath.
Posted : 29/10/2017 8:25 pm
[url= http://www.candb-seen.co.uk/product-quick-release-mt.html ]c and b seen version[/url]
The screw might need replaced though
Posted : 29/10/2017 8:39 pm
Hope Universal Bar Mount £7.99 from CRC:
http://www.chainreactioncycles.com/hope-universal-handlebar-mount/rp-prod23533
Should screw into any light with a single screw hole in the base. Fully adjustable clamp action.
The only thing you might need to change is the screw if it's the wrong diameter for your light.
Posted : 29/10/2017 8:43 pm
Thanks guys those both look awesome. I would ordinarily buy Hope but apparently the C+B one is marginally better based on the reviews.
Posted : 29/10/2017 9:27 pm
 pnik
I put the c&b one on my aldi special was a bit of a hassle because of mismatched screws, doubled up with some sugru to improve the water[s]proofing[/s] resistance. Good job and locks it nicely.
Posted : 29/10/2017 9:33 pm
I use the Hope one listed above.
Works a treat and is cheap. The screw to get my light onto it had to be cut a little, but once done has been perfect.
Posted : 30/10/2017 12:37 am
