Cheapish road wheel...
[Closed] Cheapish road wheels with "normal" spokes
[#4016097]
I bought some factory Shimano road wheels a couple of years ago and recently broke a spoke. I'm having a nightmare getting them repaired because no one stocks (or wants to order) the proprietary spokes (straight pull, flat bladed who-knows-what) that they need. I've tried several shops now and I'm getting a bit tired of being (road) bike-less.
Which brings me to the question, what wheels can I buy for up to £200 a set that come built with "standard" spokes so I can get the bloomin' things repaired if and when I do bust a spoke?
Posted : 28/05/2012 8:17 pm
£200 = cheap?
you can get handbuilt for that I'd have thought. 105 on open sport at least. With more spokes, less chance of breakage.
Posted : 28/05/2012 8:27 pm
Which spoke do you need and for which wheel?
I have the exact same problem - mine are original 105s - spokes have a kink in them and are no longer available (I snapped a rear one) but my LBS ordered in a straight one by mistake so some are still available!!
Posted : 28/05/2012 8:31 pm
CheapISH Al. Judging by what's on the market that's cheapish
To be honest I'm not sure what I need, other than it's for a Shimano RS20 rear wheel from 2 or 3 years back, straight pull and bladed. I assume I can make some measurements but what?
Posted : 28/05/2012 8:33 pm
Is it drive side or non drive side?
If they are still in stock it should be a fairly standard order for an LBS. I know they hate ordering tiny things like this but some don't realise that then you're more likely to come back for a larger purchase 🙄
Posted : 28/05/2012 8:51 pm
Not sure, and the wheel is with my old man at the moment to see if his LBS can help. Nope. That's 4 shops that can't/won't help now.
Posted : 28/05/2012 10:07 pm
 Bez
Had the same problem, broke spokes on Shimano wheels. Shopped around and got Ambrosio Excellights, 105 hubs and DT Revs for £200. If you went for Comps and a few extra grams on the rims then you'd save a fair bit - I built an Open Sport with Comps on a 105 rear hub last week, cost under £80.
The only 'factory' wheels that get remotely acceptable reviews for that money are the Halo ones.
Actually, I may have a spare black spoke for the NDS of a rear Shimano RS10 if that happens to be what you're after...
Posted : 28/05/2012 10:19 pm
