cureently run a slx 9 speed triple on the front of my Bfe and am thiking of single ring at the front as i dont thik ive used my inner ring yet!!
whats the best/cheapest way to do it then ??
the frame has 3 holes round the bottom bracket to mount a chain guide on?
cheers
steve
Don't change gear?
beaten to it ! doh!
take the other rings off, shorten the chain accordingly, remove the front mech
sorted 🙂
and remove granny ring (think of the weight save 😉 )
EDIT: garr also beaten...
bash and granny bash from bbg.
diy bionicon type guide.
about 20quid.
mrp/e13 about 120quid
might look into an unramped chainring.can skip if using the stock chring.
May as well get an unramped dh style ring, a bit heavier but ,more secure and last longer ( igot an fsa one cheap of crc)
http://www.chainreactioncycles.com/Models.aspx?ModelID=28192
and cheapest is a superstar guide,
http://superstar.tibolts.co.uk/product_info.php?cPath=56&products_id=362
the bb mounted one is better than the seat tube one, but both work fine, good idea to loctite all the bolts though
