Cheapest I have found so far is £57.68 posted. Black 11/8 standard type.
[url= http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=170413616771&Category=56194&_trkparms=algo%3DLVI%26its%3DI%26otn%3D2#ht_742wt_941 ]roteccyclesonebay[/url]
No strange colours please as its going on a white 5.5.
£56.99 @ Evans
[size=1](using the £5 off voucher I have going spare 🙂 )[/size]
Gimme a mo
DezB is a star.
FACT.
Sorry if this is after the event, but, if you went with wiggle you could use the public tenner off code posted on here by organic....I think it works till the 11th. 50 quid minimum spend...headset is 61.66, meaning you should get it at
£51.66
grrrr.
too late. Thanks Adam for the heads up (and email).
LBS - fit for free?
Wiggle sell grey imports
[size=1] the above might be a lie[/size]
DezB - Member
Imported from Yorkshire?
Nope they are made in Lancashire and therefore not quite as good
Edit: I should add that Barnoldswick used to be part of West Riding (Yorkshire) but was given away free with a packet Corflakes to Lancs after a bunch of Pendle Witches cast a spell. However this spell was not strong enough to cancel out Yorkshire Telly which is still viewed today. Some of the Kerbs are painted Red some are White.
Do not take a Whippet into a red kerb area
Do not take a Hot Pot in into the white kerb area
I have a mate with a headset press so fitting not an issue.
Decided to order a second one with the £10 off and return the more expensive one. It helps that I live in Bristol and can cycle to the shop to return it.
Thanks for the help.
"Decided to order a second one with the £10 off and return the more expensive one. It helps that I live in Bristol and can cycle to the shop to return it."
Wiggle are in Porstmouth and don't accept callers.
For headset presses, B&Q sell one. Well, they sell threaded bar, nuts and big washers. Lovely.
For anyone reading this some time when there's no Wiggle 10% offer, Bikeoutlet does Hope headsets for £54.95, free delivery, which is normally the cheapest I've seen.
[i]Wiggle are in Porstmouth and don't accept callers[/i]
He got the "expensive" one from Evans
