Cheapest and best s...
[Closed] Cheapest and best shimano hyd brake fluid alternative?
[#5435364]
Any recommendations after spilling it all over the garage this morning?
Posted : 18/08/2013 3:40 pm
I've happily used Halford Citroen LMH mineral oil, though it has been suggested it a lot thicker than shimano stuff, which also has "extra ingredients" for longevity of the seals.
PS: Obviously if your brake are under warranty, using anything but the shimano stuff, is asking for trouble (warranty claim wise)
PPS: There also an argument that you use so little fluid, that using the shimano stuff is hardly expensive.
Posted : 18/08/2013 4:00 pm
Yes. Be more careful :mrgreen:
Posted : 18/08/2013 4:05 pm
[i]There also an argument that you use so little fluid, that using the shimano stuff is hardly expensive. [/i]
This, just buy some more. After owning some old minis (that needed quite a bit of attention) I bought a 500ml bottle of LHS fluid when I moved the Shimano brakes expecting the ame sort of hassles and issues, and it was pretty cheap. I never used it after filling and bleeding my Shimano brakes once with proper Shimano fluid; and then never ever touching them ever ever again.
Posted : 18/08/2013 4:38 pm
