Cheapest 44mm taper...
[Closed] Cheapest 44mm tapered headset?
[#5591524]
As above. Anyone any suggestions, or should I just sack it and get the Hope one?
Posted : 10/10/2013 7:49 pm
Nukeproof 44IETS or superstar tapered T4 will do the job. Personally I'd get a hope though.
Posted : 11/10/2013 5:21 am
It's not tapered, but the Nukeproof one I've been using for a couple of years has been problem-free.
Posted : 11/10/2013 5:51 am
What is the time frame for cheapest? Seen a cheap one last 5 months before it needed replacement. Hope would work out cheaper fairly soon.
Posted : 11/10/2013 6:51 am
Hope every time.
Posted : 11/10/2013 7:14 am
You'll save £10-15 going Nukeproof over Hope. False economy.
Posted : 11/10/2013 9:06 am
What they said (probably). I had a Cane Creek - 10 headset and whilst it's still spinning after 6 (fairly summery) months, turning the bearings by hand it's a bit notchy. Replaced the lower cup with a hope one, which isn't a bad economy as the cheep top one will probaly outlive even an expensive lower headset.
Never had anukeproof headset so can't really comment.
Posted : 11/10/2013 9:18 am
I've had a hope and a cane creek and much prefer the cane creek. You can easily upgrade the bearings on the 10 to 40 or 110 spec.
Posted : 11/10/2013 11:01 am
honourablegeorge - Member
Is that based on personal experience?
As I say, I've been running the 44mm headset on my Mega for about two years. Never touched it and it still runs like brand new. 🙂
Posted : 11/10/2013 11:06 am
