Cheapest 142x12 hub...
[Closed] Cheapest 142x12 hub?
[#8047746]
Not for actually riding with, I need something for using in a frame while cleaning.
I've seen zee and SLX for about £40. Or I'd be happy with a knackered one so long as it actually spins.
Cheers.
Posted : 10/09/2016 9:08 pm
I need this one explained to me - a hub to fit while cleaning?
Posted : 10/09/2016 9:11 pm
Yeah, I take the wheels out to clean those and put an old hub in the frame to run the chain over while I clean that and the chainring.
Might sound odd, but it's the way I like to do it.
Posted : 10/09/2016 9:13 pm
Ah, the chain, right you are.
Posted : 10/09/2016 9:16 pm
Why not do it properly?
http://www.parktool.com/product/dummy-hub-dh-1
Posted : 10/09/2016 9:17 pm
Cheers. I've seen qr ones like that before but didn't know there was one for a 12mm thru axle.
Posted : 10/09/2016 9:27 pm
Seems you only use the roller portion for a thru axle.
Posted : 10/09/2016 9:36 pm
Yes, just been looking to see if I could just buy the roller. Lump of nylon and a couple of minutes on a lathe I'm sure it wouldn't be too trick to knock up. I just don't have a lathe.
Posted : 10/09/2016 9:45 pm
A roller off a blackspire stinger with a 12mm hole drilled out, maybe
Sure I have one in a box someplace
Posted : 10/09/2016 9:52 pm
