cheap source of cab...
[Closed] cheap source of cables?
[#1000440]
there was a post about this recently but i cant find it.i am goig to change all my cables to one contiunous length outers and also some of my kids bikes cables are buckshee.
some one listed a good source of outer cable...parkers or something?
i dont need anything amaving like gore or xtr, altho whay do people rave about the xtr ones? what better about them?
Posted : 31/10/2009 10:00 am
bump
Posted : 31/10/2009 11:07 am
 ojom
Your LBS should be able to sell you it off the roll in the workshop.
Its about £2.40 ish for an inner at the moment and £.50 ish a metre for the outer.
Or just buy some Gore ones.
Posted : 31/10/2009 11:14 am
re purplefunkymonkey link above
OUTER - described as can be used for brake or gear - ARE YOU SURE?????
Posted : 31/10/2009 11:39 am
parker international do workshop rolls for about 325
Posted : 31/10/2009 11:46 am
Dunno , I've not bought any but don't see why not.
da funk
2nd Parker's for SP41 [url= http://www.parker-international.co.uk/5084/Shimano-SP41-Outer-Casing-4mm-x-10m.html ]10 m for £24 thought it was cheaper(?)[/url]
iirc:
Spiral twist outer can compresses with gears - puts out indexing.
Longitudinal 'twist' gear cable, can split with brake cable pressures.
+ different sized inners.
Posted : 31/10/2009 12:11 pm
Purplefunkymonkey, take it you've not changed any cables before then? 😉
Posted : 31/10/2009 4:53 pm
probikekit.com
Posted : 31/10/2009 5:01 pm
Cycling weekly sell 5 packs of Clarks inners (2 brake, 2 gear) for £5.....
Even if you never use the brake cables, that's 50p each for gears
Posted : 31/10/2009 5:23 pm
so do cycling weekly and parkers have websites...?
Posted : 31/10/2009 8:47 pm
