Cheap Maplins alarm...
[Closed] Cheap Maplins alarm problems help
[#8102652]
TSG fitted a fob operated alarm for me.Its been setting itself of occasionally even when the alarm isn't triggered!Any of you had this problem?What did you do about it?Cheers for any help.
Posted : 11/10/2016 5:58 pm
Intruder alarms only usually trigger when not set for 3 reasons,
1 Tamper faults,
2 Battery problems
3 Being a bit crap.
Tamper faults are usually loose connections assuming a wired system or any of the boxes will have a microswitch or similer that might need adjustment.
I used to be in the trade and unless things have changed drastically, by your thread title I'd say it's the 3rd option.
Maybe try getting the fitters back or get a proper system installed by a firm with call out back up.
Posted : 11/10/2016 6:38 pm
Thanks,I thought a Yale lock would be decent.Its a fob controlled job and that seemed to confuse the technician.A proper alarm would be £950.00!
Posted : 12/10/2016 12:15 am
If TSG Can't/Won't help I imagine Yale will have a customer helpline.
It's over 12 years since I worked on intruder alarms but we would dread being called to a DIY system like that as they were almost always a pain in the backside.
I have no idea what would have been fitted for £950 but you would usually be able to drag somebody out at any hour to sort any issues.
Posted : 12/10/2016 4:03 pm
Fair point,it seems buy cheap buy twice is correct.
Posted : 12/10/2016 10:05 pm
I will never use Maplin/TSG again
Posted : 13/10/2016 9:49 pm
