cheap.. drop bar br...
cheap.. drop bar brakes?
[#12489310]
So, my Saracen Levarg flat bar isn't selling..
toying with the idea of single speed drop bar...
it has tektro (mineral oil) flat mount brakes already.. i figured some cheap shimano levers would sort it out... no such thing as cheap (£200 for tiagra or 105 on ebay)
any other mineral oil levers available cheap? if not.. recommendations on a budget cable set?
Posted : 02/08/2022 5:40 pm
TRP Hylex are less expensive than most if that helps, no shifters so ideal for SS.
Had mine 18months and love them
Posted : 02/08/2022 5:42 pm
 nbt
be much cheaper to get new brake levers for cable brakes and new calipers I bet. Even cheaper if you can find in Ebay. TRP Spyre, Avid BB7 are the normal cable disk recommendations
Posted : 02/08/2022 5:48 pm
Surly corner bar instead?
Posted : 02/08/2022 5:49 pm
hylex don't appear to be on the cheap side either
looks like a full mechanical setup is the cheapest way forwards
Posted : 02/08/2022 6:12 pm
@alan1977 you have a PM, sir
Posted : 02/08/2022 11:42 pm
Or buy a giant conduct master cylinder from eBay and connect it up to your current calipers and some mechanical shifters.
The giant system uses tektro calipers normally anyway. I did this but used Shimano calipers.
Posted : 03/08/2022 12:08 am
