Cheap 40T Expander ...
[Closed] Cheap 40T Expander Cog Thingy.
[#6751708]
Just a heads up to other STWers as a previous customer Works have a discount code for 20% off everything, I dont really need anything as such but they just listed their 40T expander cog thing at a cheap enough £36 which goes under £30 with the discount 🙂
Just ordered one myself for that money, will have to wait till the 19th but I am not in a rush(though winter fitness says otherwise..) was that or the Superstar one but i am a bit of a Works fanboy so why not...
oh yea, code is: thankyou
Posted : 05/01/2015 8:22 pm
Ordered, thanks 🙂
Posted : 05/01/2015 8:36 pm
Cheers for that. got the expander and a NW chainring for 53 quid
Posted : 05/01/2015 8:50 pm
For those on a budget or who want to try a 40 & 42t without the cost of buying two cogs, I have just gone for this at £12.50 delivered [url= http://singletrackworld.com/forum/topic/40-42-homebrew-adaptor-1250 ]adaptor of an stw member.[/url]
He has sold quite a few on ebay and everyone seems very happy with theirs.
Posted : 05/01/2015 9:15 pm
It seems they don't come with a smaller cog to smooth out the ratios when you remove the 17 tooth cog, does that not give you a big jump in ratios?
Posted : 05/01/2015 9:33 pm
^ I think general consensus is that they aren't much cop anyway - my one up 16t slips.
Supposedly genuine shimano ones are better if you can find one.
Posted : 05/01/2015 9:45 pm
I may get rid of the 11t and use a smaller lockring with mine, dont use the 11t really anyway....
It seems 16T rings that work are pretty rare.
That chainring adapter thing isnt my bag - lots of faff to save £15.00 and it probably wont work as well either.
Posted : 05/01/2015 9:52 pm
Posted : 05/01/2015 9:56 pm
losing the 11t and fitting an expander will make things heavier and you will not have a wider range, using a smaller front might be a better idea if you do not need the high gear 😉
edit currently testing a 10speed setup with a 40t hope/XT and 16T, prefer my home made 11-40 9 speed setup with the adaptor in terms of ratios and shifting, did spend some time faffing with it though TBH - but not much more than with the expander cog! 😆
Posted : 05/01/2015 9:58 pm
superstar showed a PIC of their new expander on their fb page today
Posted : 05/01/2015 10:02 pm
Even with this Works and the SS one being cheaper than the rest, the cost still adds up when you purchase the cassette.
When will Shimano just make a 11-40T SLX / XT cassette and end this nonsense of silly botched systems?
Posted : 05/01/2015 10:16 pm
The familiar misunderstanding about gear ratios cropping up again. I wonder how many folk have fitted 40 or 42t range expanders thinking 36 to 40, that's a massive gain; 11 to 12, that's a tiny step.
If you get your calculator out and use the Divide function rather than the Subtract (ratios involve dividing)you will find they are almost the same!!!
So, fitting a range expander (weight, cost, suspect shifting etc)and taking off the 11 will give you no range expansion just the same effect as using a smaller chainring.
Posted : 05/01/2015 10:21 pm
an 8 speed wide range system would be lighter and more suited to most peoples riding I think,
Personally have no use for 11 gears that are really close together on stuff I like to ride.
Posted : 05/01/2015 10:27 pm
I would say many buyers of these cogs are not looking to extend the range of gearing in that manner but are more looking to provide themselves with gearing suitable for slogging up a hill when using 1x10 which with most 4 bolt chainsets you are limited to a 30T ring making 29ers, long climbs and fatties like me struggle.
Posted : 05/01/2015 10:30 pm
Chickenman, no one removes the 11t, usually one in the middle, one up even give you a free 16t so you can swap out the 15 and 17t ones for it
Posted : 05/01/2015 10:33 pm
Anyone received anything yet?
Posted : 15/01/2015 9:15 pm
Theyre not getting released /dispatched until the 19th. Apparently it was on the page when we ordered. I missed it too, but emailed them and they got back with that.
Posted : 15/01/2015 10:11 pm
ah cool, ta
Posted : 15/01/2015 10:59 pm
AbsoluteBlack have a lockring type set up so that the 11T can be removed. Quite a good idea if you never find yourself using it, I have found it often skips anyway.
16T 9 speed cogs work ok, I get them from Rose Bikes.
Posted : 16/01/2015 11:37 am
You have often set up your gears poorly.
Posted : 16/01/2015 11:41 am
Read chickenmans post then explain to me the point of removing the 11 please.
Posted : 16/01/2015 11:50 am
Anyone got anything yet? Still waiting here.
Posted : 23/01/2015 5:50 pm
Mine was marked as "dispatched" yesterday so I'm expecting it tomorrow.
Posted : 23/01/2015 5:52 pm
Rubber_Buccaneer - Member
If you want lower gearing but can't go smaller than a 30T chainring perhaps?
Posted : 23/01/2015 5:54 pm
I didn't think of checking my order status, Derp.
Posted : 23/01/2015 5:59 pm
I got a despatch e-mail yesterday so should arrive soon.
There was a crazy system that had a second(!) front ring, sometimes as small as 22t which meant you could use a 34 or 36 chainring and have enough ratios to get up or down most things. You needed what was known as a 'front mech' and a 'front shifter' as well though. I think some people still use it.
Posted : 23/01/2015 6:05 pm
Yeah bit it added a pound in weight, was an extra place for mud to catch and looked a bit shit, glad they've been consigned to the dustbin of outdated bike technology
Posted : 23/01/2015 6:08 pm
You can pick up shimano road 16t cogs for £4. They've worked fine on my XT cassette/expander set up
Posted : 23/01/2015 7:14 pm
Mine arrived yesterday - comes with a longer B screw too.
Looks OK.
Won't be fitting it just yet.
I've gone from 2x9 with a 36t front 34t rear to a 1x10 with a 34t front & 36t rear. Want to try just riding that around for a bit before I decide whether to fit the 40t.
Posted : 24/01/2015 12:27 pm
Andy R - Member
Yep, arrived today - I'll fit it tomorrow.
Posted : 24/01/2015 6:23 pm
Fitted today, working perfectly with one of those 9 speed 16T sprockets and didn't need the longer B screw.
Posted : 25/01/2015 8:02 pm
