Cheap 29er hooligan...
[Closed] Cheap 29er hooligan hardtail. Does it exist?
Ha 'bike frames'. Clink can't keep em ....I can't let em go ....
Posted : 15/04/2013 8:49 pm
Matt: you can use the dmr 'simple tension seeker' tensioner on the yelli. Works really well and it tucks up nicely behind the stay so it looks really neat. Only change you need to make is the roller as the one supplied is too narrow to fit a singlespeed chain so I just swapped with an old wider on one roller i had lying around. I used it on mine during winter and it was great in the filth.
Posted : 15/04/2013 9:05 pm
There's a bronze Trek Stache in the window of H4TH, it's a beautiful looking bike. IMO Trek have nailed it there as a 'great fun for most people most of the time' hardtail.
But I think, @cheez, for outright playfulness it's still the Yelli for you.
Posted : 17/04/2013 9:58 am
Saracen kili trail 29er's worth a look?
good topic. wouldn't mind buying one myself as an alternative to the 71/73. angled 29er's in my possession.
I guess these long forked bikes would be as capable as most FS bikes in the alps?
Posted : 17/04/2013 10:27 pm
I think clink's had all of those bikes.
Posted : 17/04/2013 11:08 pm
At least I can make my mind up which wheel size to go for! 😉
Posted : 18/04/2013 6:39 am
That Trek Stache 8 is an absolute bargain. Got a demo on one on Friday.
Posted : 18/04/2013 7:19 am
That Yelli Screamy corners on tuppence, a flick of the hips, a little pressure on the bars, then some kind of time compression effect happens and I'm around the corner without any time passing.
Problem is I'm starting to learn the bike and am going straighter for longer, leaving the cornering until the last moment.
This could end badly.
Posted : 18/04/2013 8:28 am
Matt, you're right. Get out now while there's still time 😉
Seriously, though, I've never ridden a bike that was so eager to get sideways.
Fun fun fun funfunFunFUnFUN -> hospital 🙂
Posted : 18/04/2013 8:46 am
The 7 is pertier though, if I was buying that'd be a real dilemma. Luckily I'm not.
Let us know what you think of it.
 st
I'm about a month into riding my Stache 7 and it's ace, lots of fun and feels fast too, not as light as I might have hoped but I guess this is down to being my first 29er but it feels plenty quick.
Posted : 18/04/2013 9:21 am
Seems there are lots of 'fast' 29ers about. i'm sure they're great but I want something that's fun first and fast second. I need to try a Stache and FF29 but my gut tells me that - for me - they're likely to be no competition for the Yelli. Buzzard and Honzo are also on the list to try but I'm worried about the weight. After all, most of my mates are buying those 'fast' bikes.
Come on On-One, where's the cheap carbon Yelli-a-like I'm after?
Posted : 18/04/2013 12:09 pm
Any 29er with chain stays longer and HA steeper than the Yelli is a fail.
Posted : 18/04/2013 1:00 pm
In that "type" of bike anyways 😉
Posted : 18/04/2013 1:01 pm
Yup, I reckon you're right
Posted : 18/04/2013 1:27 pm
With a couple of rides under my belt, I do too. I keep thinking "what are all the other guys (brands) thinking?".
On paper the Yelli looks a bit too extreme IMO, which is why it took a small company to produce it. But in reality, it's not extreme, it's just fun, and pretty easy to ride too.
Except for the race heads, where weight and pace is the absolute priority, or marathin riders perhaps, I think it would suit anyone who wants to have fun on a bike. Other geometries are starting to feel redundant.
Posted : 18/04/2013 1:41 pm
On second thoughts maybe I should buy a Yelli..........
Posted : 18/04/2013 1:52 pm
Try 'em both if you can, I've not ridden a Stache.
Posted : 18/04/2013 1:57 pm
Trouble is I can't build a Yelli for £1800. Well, not with a spec like the Stache.
Posted : 18/04/2013 2:52 pm
That's not really the point tho is it.
Posted : 18/04/2013 3:16 pm
@ andycs I reckon you could build a Yelli with a pretty damn good spec for close to that with a little clever shopping
Posted : 18/04/2013 5:15 pm
Have been thinking about it most of the afternoon. Going to sit at the laptop and see what I can come up with.
Posted : 18/04/2013 5:35 pm
yeah me too
even at rrp
frame 850
forks 300
wheels 300
tyres 50
headset 50
= £1550
strip the rest off your 26
no need for a front mech IMO
cpuld be done a lot cheaper with judicious buying
2nd hand yelli frames seem to go in the 500-600 range
you'll be needing a dropper of course, if budget is tight run it SS and with broomsticks for the forks, but you'll be needing a dropper.
Posted : 18/04/2013 5:44 pm
 st
Don't take my comments out of context, when I say fast I don't mean head down arse up race posture. For me it's partly down to moving from a full sus (Heckler) to the Stache so I'm enjoying all the good things about riding on a hardtail over a full suspension bike.
The Stache feels great on Singletrack, leaves the ground as much as I might want it to and feels good when descending encouraging me to go a bit faster still.
No doubt some of the more niche brands have more 'hardcore" options but its the same as comparing any mainstream brand bikes with the smaller companies no matter what wheel size or suspension configuration you might choose.
Posted : 18/04/2013 5:49 pm
Sure, st, I guessed you meant 'fast like a 29er hardtail'. They're brill aren't they.
Posted : 19/04/2013 8:07 am
At the risk of reopening the dreary 26 v 29 debate, my admittedly fairly limited experience of 29ers so far suggests that 'normal' length chainstays = very stable and fast but not as playful as the 26in bikes I'm more used to riding. The Yelli on the other hand is probably the most playful mtb I've ever ridden. I'm no geometry expert but I suspect the next bike I buy will be a Yelli or something with similar geometry. That said, I'd love a go on a Stache.
Posted : 19/04/2013 9:05 am
Yelli Screamy wheelbase (medium - 100mm) 1084mm, HA 68 degrees with a 120mm fork
Trek Stache wheelbase (17.5 - 120mm) 1128mm, HA 68.3 degrees with a 120mm fork
so that's only 44mm difference, and the YS wheelbase would be a tad longer with a 120mm fork
can it really make that much difference to the ride?
I reckon the top of the Stache headtube would come out about 15mm lower, as the HT is a tad shorter and it looks to have an integrated lower headset cup, which I think would save a few mm too.
Posted : 19/04/2013 9:44 am
Kona Taro? Like a Honzo but aluminium and cheaper. Frame's presumably a tad lighter too, the Honzo is a bit of a flabby thing.
Posted : 19/04/2013 9:46 am
Well, no Stache demo today, bike not returned to shop yet. Have been giving serious thought to building a Yelli. Would like to get a ride on one but Charlie the Bikemonger is a long way from West Yorks. Does anyone know anywhere that might have one?
I don't think they're easy to find Andy, not many about. According to the Yelli site, CTBM is the 'importer', you can buy direct too tho.
Best give Charlie a ring I'd think, I dno if he has stock or demos.
Mine's in Surrey if you should happen to be down this way any time soon. Size medium.
Posted : 19/04/2013 9:53 am
Andy - Might be worth having a word with Stif if you're up that way. They bring Banshee bikes in these days and might be able to get hold of a Paradox which has similar geometry to the Yelli I believe....albeit not quite as good 😉
Posted : 19/04/2013 11:46 am
The Yelli is 2cm shorter in chainstay length, this gives the playfulness. Short chainstays on a 29er is the key, which is why the new Specialized Enduro 29 will be a big hit.
No they don't.Ison import banshee.
Posted : 19/04/2013 11:55 am
2cm makes that much difference? That's about the depth of my little finger.
Posted : 19/04/2013 12:06 pm
I used to feel the same way.So I played about with the sliding dropouts on my Unit during a ride.Changing from longest to shortest (about 25mm difference) and then re-riding sections.
Then I bought a Yelli 😀
Overall wheel base/front centre does'nt have such a large effect (despite the 'I prefer bikes that are too small because they are more chuckable' brigade) which is why I got an XL and run a 35mm stem 8)
Posted : 19/04/2013 12:12 pm
Fair dos.
I am amazed at the Yelli's small turning circle without any sacrifice in balance at low speed. I showed it to a friend who has a MCR9 and said "look it turns very quickly because of the short wheelbase", he said that's nonsense they were almost the same, we put them side by side and he was right.
Posted : 19/04/2013 12:15 pm
Ok, fair point but slightly facetious. Andy, might be worth having a word with Stif as they sell Banshee and are in your area. Alternatively Ison may be able to direct you.
matt - Only 2.5cm difference between the Yelli and the Swift and how differently do they ride. *Obviously other factors at play*
Posted : 19/04/2013 12:26 pm
More factual than facetious 😉
Pat keeps me in cakes and salsa stickers so I have to keep him sweet.
Posted : 19/04/2013 12:31 pm
Ah fair enough, you caught me grumpy and short of caffeine 😀
Posted : 19/04/2013 12:33 pm
Why don't Kona do the Taro frame only, instead of draping it with dross components?
I reckon there's a serious gap in the mtb market. Kickstarter anyone?
Posted : 19/04/2013 12:39 pm
On-one missed a trick - they should have produced this frame years ago.
Posted : 19/04/2013 12:49 pm
This x10.
Posted : 19/04/2013 3:29 pm
How close is the Fineline Evo?
Posted : 19/04/2013 3:53 pm
Page 2 / 3
