Charger Damper upgr...
Charger Damper upgrade for Reba/Sid or new fork?
[#13086345]
Lots written and available about the various charger damper upgrades n the longer travel trail and enduro forks - and I used to have a Charger 2.1 Pike on a differnet bike which was a great fork.
Not so much about the skinny and short forks though.
Exhibit A - my XC bike. Nearly a year old, love it, only issue is I'm not over the moon with the fork. It says 'SID' on it but its actually a bastardised combo of Reba RL with a Sid Air spring, MoCo damper and SID lowers running at 110mm. Owes me very little, light, looks good, but performance average especially as the rest of bike just wants to go flat out all the time.
Getting a lot of hand pump, numb palms and general 'budget' fork feeling. Charger upgrade is available for £100.... Worth it? Will it make a difference?
Maybe better to look at another fork?
(I do have the option of moving my 2022 Fox 34 (Amazing) across to this bike, puttign a 120 air spring in it and getting a 36 for the trail bike....)
Posted : 20/12/2023 4:51 pm
 DrP
I did a thread about stocking a charger damper into a reba with moco... MUCH better...
Where have you seen it for £100??
DrP
Posted : 20/12/2023 9:45 pm
nuke and nuke reacted
Just do this. Air spring for the Fox will be around £40 and if you are competent enough to service fork lowers then its an easy job to do at home. XC's all about 120, thicker stanchioned forks nowadays anyhow.
Posted : 20/12/2023 10:33 pm
Bike looks awesome.
But the real question is surely which fork do you really want on the other bike? 😉
Posted : 21/12/2023 10:16 am
Treat yourself to some lovely Blue Sid ultimate SL i have just put up for sale in the classifieds 🙂
Posted : 21/12/2023 10:39 am
£100 for a charger damper upgrade is definitely worth it..... Noticeable difference on the trail.
Posted : 21/12/2023 10:53 am
 nuke
Ha, this +1 👀
Posted : 21/12/2023 11:10 am
👀 +1
Posted : 21/12/2023 11:36 am
 DrP
i've just found that too!
But am now looking at the 35mm raceday damper for my SIDS...wondering if it's worth turning them into ultimates (currently select)
DrP
Posted : 21/12/2023 12:37 pm
that's  avery good deal and worth the upgrade. I have the charger upgrade in a set of sids and it's made the fork behave itself very well.
Posted : 21/12/2023 6:16 pm
Depending on the year of your SID’s OP I might have your MoCo damper off you if you’re willing to sell at a reasonable price. I’ve got some Reba’s with a damper which I think it a bit stuffed but not fussed about upgrading to Charger as it’s only a knock about bike. PM me if you’re interested.
Posted : 21/12/2023 6:59 pm
I'd guess from the charger upgrade link it's going to be 2018+, IIRC the threads are slightly different for older ones, but I've not got any of the newer ones to try them!
I got the charger 2 damper in my sids for the older model. I also have a couple of MoCo dampers in the shed for older forks (2012-2017) shoud you need one.
Posted : 22/12/2023 10:50 am
Just be aware the linked damper is for 100mm max in 32mm chassis only. The OP states 110mm travel so no good for them.
If anyone spots a nice deal on 35mm SID 120mm ultimates please post it up.
Posted : 22/12/2023 11:07 am
 DrP
https://www.bike-discount.de/en/rockshox-sid-ultimate-race-day-29-debon-air-120-tapered-boost?number=20086796-40220308&__delivery=11&__currency=1&srsltid=AfmBOoolwaE21IuDX-SqanhAl83FTfmSv7sE6rm78AWe2mw5vEGg2EooTQ4
Bike discount have bonkers prices on multiple versions of SIDs...
£359 for a newer version, jsut without twist grip remote...
Will get stuck for import duty though, right..
DrP
Posted : 22/12/2023 11:13 am
I make that £475ish depending on shipping once import and vat added. Still better than UK prices. Stuck between upgrading my pike to with a lockout or a SID.
Posted : 22/12/2023 12:36 pm
 DrP
I was touing with upgrading my SID damper to the race day...but... I've read reviews that the race day damper is SO lightweight, that it can be a bit fragile, adn less damened.
I think, actually, that the charger damper probably suits my needs better...
<br />DrP
Posted : 22/12/2023 1:17 pm
