Charger 2 damper bl...
[Closed] Charger 2 damper bleed
[#10785803]
Is the bleed kit for the charger 2 damper different to that for the charger 1?
It seems like they are bled in a different way, but there only seems to be one type of bleed kit available to buy which doesn't specify a version.
Posted : 28/08/2019 12:59 pm
I'm sure it's different. I have the Epic bleed solutions kit and it has 2 different adapters in the kit.
Posted : 28/08/2019 1:04 pm
Thanks. Just found this which seems to confirm that they are different (and probably most kits come with both).
https://www.bike-components.de/en/RockShox/Charger-Bleed-Kit-p40248
Posted : 28/08/2019 2:39 pm
Posted : 28/08/2019 2:45 pm
RS spare parts catalogue lists the following:
11.4318.010.000 FORK BLEED KIT - CHARGER 1 DAMPER FITTING (FOR BLEEDING CHARGER 1 DAMPERS) - BOXXER 35mm B1-B2 (2015-2018)/PIKE A1-A2 (2014-2017)/LYRIK RCT3 A1, RC B1 (2016-2017)
00.4318.007.000 ROCKSHOX CHARGER DAMPER STANDARD BLEED KIT (INCLUDES 1 SYRINGE, CHARGER BLEED FITTING, SUSPENSION OIL 3W)
Posted : 28/08/2019 3:05 pm
