Charge Plug chainse...
[Closed] Charge Plug chainset/BB compatibility
[#10950256]
I've got a '16 Charge Plug with Claris stuff, most of which is near the end of its life. It's my commuter, pretty flat round here, and I value simplicity, so is there any reason I can't replace the chainset with a cheapish 1x MTB one? Providing I can find a suitable sized ring?
Ta!
Posted : 07/12/2019 9:07 am
I've got a similar aged one, it'll work fine. It's a 68mm shell so will need 3 spacers for an MTB crank instead of 1 for the road crank, if you're running a hollow tech bottom bracket. I've got an XT BB and SLX cranks on mine at the moment.
Posted : 07/12/2019 6:11 pm
Aces, thanks very much! What size ring did you use(and where from?)? Just wondering what there's room for at the stays with it in a decent chainline.
Posted : 07/12/2019 9:29 pm
No worries. Just the outer ring of a triple set of chainrings in the middle position of a triple chainset. It's a 42t and there's plenty of room.
Posted : 07/12/2019 11:50 pm
