I'd appreciate knowing what others are riding as I'm on the cusp of M and L - well, just over into L with being a shade over 5'11 but...
Sizing against my 56cm Day 1 [u]which is great[/u] (ETT 555mm) would put me on a M
My M Cotic X is a [u]bit on the small size[/u] (ETT 548mm)
M Plug ETT 565mm, 5'6"-5'11"
L Plug ETT 575mm, 5'11"-6'2"
Argh! What are others around 5'10" - 6' riding and how do you find it? Not sure I can find one to try...
Somboddy mus av wun?
2014 model + "a shade over 5'11" + medium size = just right for me
I had the 2016 single speed pink one. I'm 5'11". Went for the medium and definitely the right choice for me.
tbh I'm 5'11'' and a half so always caught between a medium and a large on many bikes.
if you're fairly bendy go for the medium as they do tend to size up largish.
I'd say the Medium would be perfect. I'm exactly the same height as you ( > < under 6ft) and used to ride a Specialized Tricross with the same ETT as the medium Plug. 110mm stem, perfect.
Pink SS one here too. 6ft on a large, would have been better on a medium tbh.
2016 5' 10", medium. Even if its off the interwebs they'll let you swap it if it's wrong
A great help folks - thanks - not sure I'll get a chance to swap, as frame only
I'm 5'11" so borderline medium /large.
I have a 2016 medium and it seems to fit me fine.
Plug 5 ti owner and 5'11" and a bit, 34 inseam I ride a medium.
Thanks wzzzz - you are exactly the same dimensions as me and I'm just about to pull the trigger on a ti frame tomorrow. Incidentally, what stem length are you running? Thanks 8)
