Charge damper oil?
[Closed] Charge damper oil?
[#8163090]
Hi all. In the process of replacing all the seals on a Pike, including the damper. Anyone know how much 3wt oil it takes to fill it from empty?
Oh, and will the 3wt work in a Reverb? Pretty close to 2.5! 😆 😳
Posted : 16/11/2016 10:18 am
Anyone?
Posted : 16/11/2016 1:20 pm
Manual link below.
The volume is listed as "bleed", so I read it as "as much as it will take to displace all the air inside"; and it's 5wt in the damper.
Posted : 16/11/2016 1:23 pm
Cheers mate. Going by the others it looks like around 100/150ml.
Posted : 16/11/2016 4:19 pm
It's 3wt in the damper and that chart clearly states that!
Posted : 16/11/2016 5:07 pm
You are right, not sure what I was looking at...
Posted : 16/11/2016 7:22 pm
