Changing the seals ...
[Closed] Changing the seals on my Mono M4's ???
[#430562]
Im planning on putting new piston seals on my Mono M4's, but cant find any distructions on Hope's site or via Google.
Has anyone done it ? Im assuming is simple, but would like to know of any issues / problems / techniques before hand.
Do I just pump out the pistons, clean replace and push them back in, then blead - or is there more to it ?
Cheers.
Posted : 28/03/2009 6:30 pm
If it's the mono, you'll need to tool to take the piston caps off so you've got room to work. They're not the easiest Hopes to fettle but with a bit of patience and thought, straight forward enough!
Posted : 28/03/2009 6:41 pm
Do I need a special tool to remove the caps ?
Posted : 28/03/2009 6:49 pm
for M4's the caps are different sizes so you need two special tools
Posted : 28/03/2009 6:51 pm
It is possible to do it without the bore cap tool, carefully remove the pistons and seals with a screwdriver. Easy if your a gynocologist..
Bore Cap tool will save a load of hassle though...
Posted : 28/03/2009 7:02 pm
Its not technically difficult - just a right faff. IIRC it can be done without removing the bore caps but then becomes even more off a faff
Posted : 28/03/2009 7:04 pm
