Changing MoCo dampe...
[Closed] Changing MoCo damper in Rock Shox Recons
[#3319575]
Afternoon.
I have a pair of Recons nut the damper is seized so I bought a new one. To change it do I need to strip them down (lowers off etc.) or can I just take the damper out from the top?
Would rather avoid taking the lowers off as the oil is fresh and clean (that is when I found the damper was seized)
Advice appreciated.
keppoch
Posted : 05/11/2011 3:16 pm
 nuke
All done through the top...no need to remove lowers. Other than the usual general tools, you'll need some 5wt fork oil and a 24mm socket.
Posted : 05/11/2011 3:46 pm
