I have always used white lightning clean ride lube and it works for me. I have just run out and the LBS only has Muc-off dry lube. Anyone used it. I have buying a bottle of lube only for it to be cr4p!
If it helps, muc off wet lube is excellent.
I've been using the muc-off dry. it does need a couple of applictaions to really 'sink in' but has otherwise been fine. Chain and drivetrain stay nice and clean too.
Well quite a few people (including me and my mates) on here use squirt chain wax - you have to dgrease you chain and apply but great - Prob have to apply as much or poss less than "dry lubes".
www.in2dust.co.uk
Free P&P and next day usually IIRC
Why not buy just buy the stuff you want from [url= http://www.wiggle.co.uk/p/cycle/7/White_Lightning_Clean_Ride_Lubricant_120ml_Bottle/5300003784/ ]somewhere[/url] that will deliver it to your door?
Rock N Roll, totally dry, totally clean and totally silent running drivetrain. You will be amazed. No I'm not on commission
Problem is I am due out at 7:30pm and have just degreased my chain thinking I had some left. Hoping I can borrow some and then order the stuff I want tomorrow but don't fancy 20 miles tonight without lube!!! Thanks for the suggestions
I use 3in1, its good.
