Changing Liteville ...
[Closed] Changing Liteville headset
[#8025905]
Has anyone successfully removed the headset cups without using a press like the Liteville bespoke one? I've tried to drive the lower cup out but just succeeded in driving the lower bearing out. In its component parts.
Posted : 30/08/2016 4:14 pm
yes I did mine recently. Everyone raves about the Across headsets but I found mine to be rubbish, letting in water grime from the bottom. So I replaced it with a nice Syncros one. Crucially get one with a rubber seal on the crown race.
Anyway I'm waffling....
I managed to knock the bearings out first too - but keep at it - there is just enough material to knock the cup out if you find the right implement - think I used a flat head screwdriver or similar....and keep changing the end you whack so it comes out evenly.
Posted : 30/08/2016 4:19 pm
Thanks - that's reassuring. First time ever but I've booked it in at the LBS to do as while I have a press to put the cups back in I want to be able to use the cups again and don't have the Park removal tool. Using a screwdriver was starting to muck up the seat for the bearing, so I stopped.
I've not had a problem with muck getting in and just want to try the 1.5deg slacker option, to max out the gnarr...
Posted : 30/08/2016 4:47 pm
