changing hope bore ...
[Closed] changing hope bore caps
[#2750187]
how easy is it to change on a X2 caliper ?
Posted : 13/05/2011 9:15 pm
You have to remove both pistons.The bore cap screws in from the inside on the x2 calipers now (grrr).Pop the opposite piston out by pumping the lever then screw the bore cap clockwise until it pushes the other piston out,then remove the piston seal and then the bore cap.Reverse,bleed bish bosh.
5/10 on the workshop hardness scale.
Posted : 13/05/2011 9:27 pm
hmmmmm might give it a go ?
Posted : 13/05/2011 9:32 pm
