Changing hope beari...
[Closed] Changing hope bearings
[#4812429]
Im new to this and want to save my self some cash by doing it my self, i can buy the bearings no probs but im not sure how to take them out and replace them into my hope pro 2 front hub, easiest way, suggestions pls!
Posted : 29/01/2013 7:18 pm
there is a video on Hope techs youtube page for the Pro 2 front hub.
Posted : 29/01/2013 7:20 pm
link me cause i cant find it 🙁 theres one for a 20mm conversion and a rear hub strip...
Posted : 29/01/2013 7:30 pm
Rubber mallet and flat screwdriver to knock out , one of the old bearings and rubber mallet to put back in. It's that simple , did mine last week for the first time and was suprised how easy it actually was.
Posted : 29/01/2013 7:31 pm
so ur saying once u get the bearing out put the old bearing on top of new and gently tap in? what about the c-clips just a small screw driver? what if u dont have a tiny one and there all normal size lol
Posted : 29/01/2013 7:35 pm
If you don't have a small screwdriver use a pointed blade knife from the kitchen , yes use the old bearing to seat the new one.
Posted : 29/01/2013 7:38 pm
awesome mate, i know alot of things but when it comes to knocking bearings out its just something ive never done so its time to learn something else new i guess 🙂 cheers buddy !
Posted : 29/01/2013 7:48 pm
oh and one more thing, do i need to add a little grease behind and on top of the bearing on replace? or just clean it out and place it straight in ?
Posted : 29/01/2013 7:49 pm
it is a really simple job and a pleasure to do, no more than an hour tops for the first time.
Posted : 29/01/2013 8:02 pm
To remove, smash with hammer. Reassembly is the same as disassembly.
Posted : 29/01/2013 8:03 pm
ok just managed to " smash em out " with a hammer and screw driver, they came out brown tatts few balls popped out and a smell of burning lol, cleaned up the hub inside, all ready for new bearings, i take it you place on bearing in first then put the little axel tube in sitting on the bearing and pop the other on top ? if im correct, correct me if im wrong 🙂
Posted : 29/01/2013 9:05 pm
Posted : 29/01/2013 10:43 pm
