Changing from a 28 ...
[Closed] Changing from a 28 tooth to a 32 tooth chainring
Sorry for the simple question, I did search the internet but couldn't find a related answer.
Got a new bike that runs a 28tooth front sprocket and a 10-42 on the rear. I am looking to go back to a 32 on the front as I had on my old bike, will I need to add any links to the chain?
The bikes new so I dont have any spare links for it, so if I do need to add links a new chain would be needed, which I am hoping to avoid!
Posted : 24/02/2017 10:10 am
Sram I think said the 11sp could go 2t up or down without altering the chain so it really depends how it's been trimmed.
Posted : 24/02/2017 10:11 am
Is that existing 28T 64BCD?
If so, biggest ring you can replace it with is 30T, IIRC.
32T ring would require 104BCD option of crank.
Posted : 24/02/2017 10:46 am
n0b0dy0ftheg0at - Member
No, sorry should have mentioned its the raceface cinch system.
Posted : 24/02/2017 11:21 am
what bike? (more specifically), what wheel size?
Posted : 24/02/2017 11:23 am
nickc - Member
The bike is a 2017 Specalized Enduro with the big ol wagon wheels that are 29! ๐Ÿ™‚
Posted : 24/02/2017 1:20 pm
bear in mind it will be like going from 32t to 34t on a 26" bike.
I'd probably fit a new chain rather than muck about with extra links if I was replacing the chain-ring, and depending on how old the cassette is, change that as well.
Posted : 24/02/2017 1:28 pm
Buy a spare chain and make the correct length. Add the left over links to your old chain and alternate between them. Much better way to manage your drivetrain wear.
Posted : 24/02/2017 1:54 pm
 D0NK
was your old bike the same wheel size/type and running the same cassette?
apologies if you know this already but if your old bike was a 26er and you're now on 29+ the swap may leave you with rather tall gearing. Plenty of gear calculator apps around to check.
I [i]thought[/i] BCD only limited the smallest ring you could put on, bigger is fine. Sure enough manufacturers aren't likely to make a 53t 64bcd ring but I'd have though 32/34 rings would be available.
<edit> oh and good luck, cinch was easy to swap over but getting the cranks off was a job and a half, mrs stood on the crank arm, me stood on the long allen key, CRACK! as it undid. Maybe no grease/antiseize when fitted, dunno, worried me tho.
Posted : 24/02/2017 2:11 pm
